kyocera CS3011I 0501 jam error HELP
  • printlessguy
    • Sep 2015
    • 63
    #16
    Re: kyocera CS3011I 0501 jam error HELP
    these 2 parts
    • Scottb
      • Apr 2013
      • 308
      #17
      302KV44041 fig 23 could be one of these is a little rusty...
      • printlessguy
        • Sep 2015
        • 63
        #18
        thanks for that option but already replaced that whole drive unit......
        • printlessguy
          • Sep 2015
          • 63
          #19
          finally got the frame rail.it came slow boat from china...... put it in and yeah it works
            • 23010
            #20
            So do you think that the tray was sliding open by itself, incrementally disengaging the lift drive and separation lift?
            Thanks for following up. =^..^=
            • printlessguy
              • Sep 2015
              • 63
              #21
              from what i can gather the customer uses pre printed Dr. forms. instead of using the bypass tray. they open cassette 1 and put 1 form on top of the paper and then print. they probably do this 20 times a day. it has worn away the support as you can see in the differences in the photos. I think what has happened is instead of the tray lifting up when fully inserted the tray is now tilted towards the back of the machine only allowing a little bit of the rollers to contact the paper and hence causing the 501 error. a bearing or a sintered roller would be a good modification in future designs .... not a fun job to replace but better than the toner supply augers on a 406ci. i'm gonna make the boss do the next one....
              • JR2ALTA
                • Feb 2010
                • 2033
                #22
                The nice thing about tray 2 issues is that you can pull out tray 1 and watch. No such luck in your case.
                But glad it worked out, a big attaboy to TonerKiller!
                  • 23010
                  #23
                  Wow! Significant wear! =^..^=
                  • tec966
                    • Mar 2009
                    • 42
                    #24
                    Hi, can you give me the part code of this parts ?
                    Thankyou.
                    • printlessguy
                      • Sep 2015
                      • 63
                      #25
                      check the 16th post in this thread the pics have the part numbers.
                      worst thing about this one was. got it fixed brought it back worked great. but customer had bad taste in mouth so traded in for a 3012i. 4 months later guess what I'm replacing in their office on the new machine..... ugh....
                      • tec966
                        • Mar 2009
                        • 42
                        #26
                        I have the same problem on a 3012i right now, hope that kyocera will fix that rail....
