km 4500i doc feed jams
  • jper34
    • Sep 2011
    • 225
    Hi Folks,
    I have a Kyocera KM4500I series the document feeder jams intermittently, after the last sheet comes out of the feeder. Most times, it works fine..but when it acts up..any suggestions, the rollers and belt, seem fine..I've cleaned all the sensors, rollers, so forth..I can show up, and run the heck out of it..it will work fine..Thanks, in advance for any input !!
    Jaime
    I.C.S.
  • Ropariva
    • 588
    • JR2ALTA
      • Feb 2010
      • 2017
      Re: km 4500i doc feed jams
      There's a one-way in the back that causes two-sided jams with one sheet just about exited like you describe.
      Otherwise I've had 1mil+ on ADF that needed all the convey rollers replaced due to narrowing.
        • 22698
        If they're J9000 jams, I'll agree with Ropariva. The original detection flag does a little bounce as it drops from the last original, detecting a phantom original. On a few machines I added a torsion spring to damp the bounce. Do I have a photo? Yes:
        Oops ... that's Amber running off with my socks.
        There it is:
        • jper34
          • Sep 2011
          • 225
          [ATTACH=CONFIG]42712[/ATTACH]
          There it is:
          [ATTACH=CONFIG]42714[/ATTACH][ATTACH=CONFIG]42713[/ATTACH]
          Black Kat,
          cute cat...but you may be right, it doesnt matter if it is double sided, happens on single sided copies, too...that darn cat !!
          I'll check tomorrow for that flag bouncing..I'll let you guys know, what I find..Jaime
            • 22698
            The way I caught this was by removing the outer skin of the top door, then running just single pages. You can see the flag operate. It only uses gravity as a return. =^..^=
