CS 5053ci Timing out while pdf printing
  • Scottb
    • Apr 2013
    • 306
    The test print was a 9 page pdf and after sending about 11% to the copier it hangs up. It prints word docs just like its supposed to. This is a new install with latest firmware and drivers. Has anyone seen this before and if so what was the cure.
    Thanks in advance
    • 23009
    Re: CS 5053ci Timing out while pdf printing
    Just the one document, or other PDF's too? I've come across corrupt PDF documents that turn into a PostScript error about halfway through. =^..^=
    • Santander
      • May 2009
      • 768
      Agree with Blackcat, is it just one pdf or multiple pdf's? Have you tried to print the pdf as an image? Had a case a year or so ago where a customer could not print purchase orders from a customer that were emailed to them. Turned out the purchasing software the customer was using was creating pdf files that Acrobat could not translate. Printing the PO's as an image would work, but of course the customer blamed the machine for not accepting any pdf, even it was corrupt. Try printing the PDF file as an image. If it works, I would be strongly inclined to believe that the program creating the PDF is causing the problem.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1888
        Windows updates change the default PDF viewer to Edge. It's garbage & most end users can't change it open with Acrobat Reader. Had a 28 page PDF that was over 1gb when printing with Edge. Use it with the KX driver & you won't have a problem.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
          • 30294
          Try changing emulation on the KX driver . See what works best
          • Scottb
            • Apr 2013
            • 306
            The following fixed my issue
            Advanced tab>Print as image
            Properties Tab>Imaging>Color Selection>Text and Graphics
            Thanks for the help guys.
