km 5050
  • everestphotocopy
    • Jun 2019
    • 8
    [Misc] km 5050
    When I try to do 2 on 2 sided scan on my machine it shows "cannot use this function".. does anybody knows whats the issue??
  • GESPAGE
    • May 2011
    • 40
    Re: km 5050
    do a 906 ?
    • everestphotocopy
      • Jun 2019
      • 8
      Re: km 5050
      tried... didn't work..
        • 29695
        Re: km 5050
        Check connectors on machine, look for a bent pin or wire pushed out of harness
          • 22985
          Re: km 5050
          I'm thinking that if you were to check the error log you would find C0630.
          Turn off the power and re-seat the lower DP connector. You may find that the connector is damaged by leaving it connected during transport. Whenever I moved these machines I disconnected both DP connectors and taped them to the top of the machine.
          • everestphotocopy
            • Jun 2019
            • 8
            Re: km 5050
            tried that. it didn't work. thanks for the suggestions.
            • B0265
              • Jan 2007
              • 718
              Re: km 5050
              Can you copy/scan 1-sided originals from the document processor?
              • everestphotocopy
                • Jun 2019
                • 8
                Re: km 5050
                yes one sided works fine.... but when I try 2 sided it displays cannot use this function.
                • zoraldinho
                  teacher-guide-expert-guru
                  • Mar 2008
                  • 5003
                  Re: km 5050
                  Plain paper? I'm not familiar with this model but most copiers do not allow duplex scanning or printing if selected paper is too thick or too small.
                  Have this model option in service mode to check duplex clutch, motor, sensors ..?
                  • kaborwen
                    • Feb 2010
                    • 146
                    • shaip
                      Re: km 5050
                      Wipe the white reference roller in the DP and make sure its white. It greys up over time and cant function.
                      • darry1322
                        • Oct 2010
                        • 817
                        Re: km 5050
                        Have you tried 2 sided original to 1 sided copy to see if it's adf or engine that is restricting duplex?
                        • everestphotocopy
                          • Jun 2019
                          • 8
                          Re: km 5050
                          2 sided to 1 also doesn't work.
                          • kjg
                            • Mar 2009
                            • 111
                            Re: km 5050
                            after you 906, What is the code displayed on the screen before 2 sided failure message posts? Most likely a bad connector on back of machine that goes to CIS. I have had a couple back in the day where the CIS failed, but usually the copies were full of random lines and garbage on second side. White reference roller possibly could be causing a white balance error if very dirty or not making full contact with CIS when closed. Just a point to check.
                            • everestphotocopy
                              • Jun 2019
                              • 8
                              Re: km 5050
                              No code is displayed. Simply says "cannot use this Function".
