Kyocera Taskalpha 4500 Developer Housing fix
  • Doug James
    • Jan 2012
    • 935
    [CQ] Kyocera Taskalpha 4500 Developer Housing fix
    Is there any developer material in the developer housing of these machines. I have several that are bad and want to fix them (Light copies) Wondering if I could just vacuum them out and wipe the mag roller and fill with OEM Toner... Any help would be so appreciated....
  • Santander
    • May 2009
    • 768
    Re: Kyocera Taskalpha 4500 Developer Housing fix
    Check your service manual or TB1, it will tell you whether the system is mono-component or dual.
    • Doug James
      • Jan 2012
      • 935
      Thanks !! That was a GREAT Idea... It said this...
      Development system-
      Touch down developing systemDeveloper: 2-component
      Toner replenishing: Automatic from the toner container and toner hopper
      So I guess it does use a developer material... THANKS FOR YOUR RESPONSE !!!
        • 22751
        Yes, starting with the Alphard I and II's most Kyoceras are dual component developing. For those of us used to the Falcon I, II, III, & Stratos it's a bit disappointing. Monocomponent developing as a rule requires very little service, barring generic toner. I know of no source of Kyocera developer only. =^..^=
        • Geo
          • 660
          What Blackcat eluded to ...are you using generic toner this could very well be your problem.
          Cheers.
          • Doug James
            • Jan 2012
            • 935
            Cheers.
            I think that is what happened to most of them.... I replaced them with known good ones,,,,
