kyocera taskalfa 5500i dead display
  • makeacopy100
    • Oct 2019
    • 24
    [Dead] kyocera taskalfa 5500i dead display
    hi there! i have a model task alfa 5500i machine with a counter about 150k the condition is excellent with 95% toner gauge
    machine was working fine last night but in the morning it was completely dead i can sound the rotation of the machine but no display.
    i refereed the user manual but it have nothing like this topic
    any one have idea about it??
  • mr panasonic
    • Apr 2015
    • 5
    Re: kyocera taskalfa 5500i dead display
    the main board has to be replaced,but first try to clean ram on the board
      when you said 'dead'
      no lights on control pnl?
      is 'energy save" on?
      I WOULD NOT REPLACE ANY BOARD till I knew for sure that is the problem.
      some newbie techs will jump right on "board replacement" before they logically think the problem thru. Boards cost $$$$$ and I refuse to waste money UNTIL I know for sure that is the issue.
      If you find out a board is needed, then I would contact these folks:
      Factory Authorized Circuit Board Repair by Hytec Dealer Services, Inc.
        • 22930
        Two things I'd do first:
        1) Attempt firmware.
        2) Remove the fuser and see if the machine will boot to an error.
        • makeacopy100
          • Oct 2019
          • 24
          no single light on pannel and but i can hear the sound of rotation, fans, even scanner comes to home after i lift up the ADU but no display these as my research says that this is a failure of main logic board because the panel is directly connected with logic board
          thus, i still believe that this problem can be solved by firmware update but i dont have firmware if you could help me for finding its firmware it would be very gentle of you
          • makeacopy100
            • Oct 2019
            • 24
            i will try to do what you said on number 2
            i dont have firmware of this copier can you link me the address from where i can get the firmware
