Kyocera FS4200Dn
  • Brandon
    • Jun 2019
    • 72
    #16
    Re: Kyocera FS4200Dn
    Originally posted by dalewb74
    i used to see this on an older model kyocera printer years ago. i believe replacing the imaging unit usually fixed it.
    • CWP
      • Jun 2013
      • 168
      #17
      Feed a sheet of legal or similar through the bypass and watch it to see if it feeds, then stops momentarily, then continues. Your registration roller may be turning all the time causing the image to be shifted down. Also, can you scan service status pages so some of us can see printer settings?
      • Brandon
        • Jun 2019
        • 72
        #18
        SMOT-JHB19110107510.pdf
        • CWP
          • Jun 2013
          • 168
          #19
          Brandon, it still looks like the registration roller is turning all the time causing the paper to feed under the drum prematurely (beating the image). You may be able to tell if you try what I ask; feed a legal sheet from the bypass because it should be plenty long enough for you to see if it feeds to the registration roller and then stops momentarily. If there is no pause at all from the moment it is pulled from the bypass then the registration roller is turning all the time. If that is what is happening then it is either the signal to the clutch holding it on (not likely) or the clutch is just really gummed up and turning all the time (more likely), especially with the number of pages this printer has seen.
          • Brandon
            • Jun 2019
            • 72
            #20
            Originally posted by KYO_OEM
            did you tried another drum unit?
            below drum unit you`ll find the registration sensor.
            Have had broken drum pwb and/ or bad connection between drum and system.
            hi , yes tried another drum unit but made no difference
            • Brandon
              • Jun 2019
              • 72
              #21
              hi , it feeds , stops and feeds again , not continuously
              • KYO_OEM
                • Aug 2011
                • 709
                #22
                We are talking about system >1.488 Million pages!
                Expected lifetime = 990.000 pages.
                Inside from 6th Generation printers >45ppm you`ll find 1 registration switch and 1 image switch.
                I think your image switch can be the problem.
                Look at the partslist Fig 4/ Paper Feed section/ item #8/ 302LV24100 and check if it`s grinded from paper.
                As you know, this switch is controlling leading edge laser start timing.
                  • 22999
                  #23
                  Come to think of it, I think I've seen a registration switch nearly cut in half at 1.8M prints.
