Kyocera FS4200Dn
  • Brandon
    • Jun 2019
    • 72
    Kyocera FS4200Dn
    Good day
    I hope im on the right form as i am a new user
    i have a Kyocera FS 4200dn that is giving me a headache , client reported that the printer is not printing correctly i.e the heading of the letter head starts printing in the middle of the page , i have replaced all the clutches and feed rollers and made no difference at all , its almost as if the paper is fed too early or the machine starts printing too late
    any suggestions and assistance will be appreciated
    • 30294
    Re: Kyocera FS4200Dn
    Does it do the same on status page?
    • Brandon
      • Jun 2019
      • 72
      yes on all pages printed from the memory or sent to the printer
      • mita
        • Sep 2010
        • 87
        I would look at paper feed/registration clutches or if it has a lot of prints on it the registration switch lever being worn off
        • Tonerkiller
          • Oct 2012
          • 668
          Is there a spring missing from the feed assy, or is the sep roller spring missing?
          • Ctl-Alt-Del
            • Jul 2006
            • 430
            Does the registration vary at all or is it consistently off by the same amount? What's the total page count on that thing? have you tried the MP Tray or Duplex?
            • Brandon
              • Jun 2019
              • 72
              I have replaced all clutches in machine , made no difference
              • Brandon
                • Jun 2019
                • 72
                nope all in place
                • Brandon
                  • Jun 2019
                  • 72
                  registration stays the same , does the same on MP tray and duplex
                    • 23009
                    Can we see a sample please?
                    Hey! Is the letterhead printed on another laser based device, maybe color? So when you take this color image fused at 160C then run it a second time through the Kyocera printer fusing at 180C the image loosens and reprints at 110mm intervals (the interval of the fuser)?
                    Sorry to say, there's nothing you can do about that.
                    • KYO_OEM
                      • Aug 2011
                      • 721
                      did you tried another drum unit?
                      below drum unit you`ll find the registration sensor.
                      Have had broken drum pwb and/ or bad connection between drum and system.
                      • CWP
                        • Jun 2013
                        • 168
                        Can you post a sample image so we can see what it is doing, and the status / service status pages just in case it is a setting that needs to be changed?
                        • dalewb74
                          • Feb 2018
                          • 1157
                          i used to see this on an older model kyocera printer years ago. i believe replacing the imaging unit usually fixed it.
                          • Brandon
                            • Jun 2019
                            • 72
                            thank you for your reply
                            the letterheads aren't preprinted even if you print a status page or menu map it starts printing from just above the middle of the page , it looks like either
                            page has fed too early or the printing started late
                            • Brandon
                              • Jun 2019
                              • 72
