Original size detect
  • ntbann
    • Jan 2012
    • 627
    Any one have a problem with a 8001i not detecting the original size from the glass? When i put an 8 1/2x11 on the glass it says that its 11x17. I have tried a size sensor and u099 size calibration. Neither has worked. Thanks in advance!
  • lees
    • Apr 2011
    • 95
    Re: Original size detect
    Check the sensor on the white reference strip of the document processor. You can check it in maintenance mode 31 or 32. I have had the sensor come out of place and I have seen the actuator on the white reference strip broke. Sounds like the machine does not know that the DP is closed. You can also leave the DP open just a little and it will probably work fine, but if you close it completely, it reverts back to 11x17.
    • Santander
      • May 2009
      • 768
      Per chance are there any marks on the original plate or pen marks on the glass that is throwing off the size sensor? I know it is a stretch, but if you have already replaced the size detection sensor and run U099 it could be worth a look. Reducing values in U099 from the defaults could actually cause the unit to detect the plate as being an original and causing your problem. Hope this helps.
      • JR2ALTA
        • Feb 2010
        • 2030
        I had, I believe a 4551, with this. Turned out to be the scanner pwb.
        • ntbann
          • Jan 2012
          • 627
          Thats what I was thinking. I noticed that if I push the switch that the document processor activates when closing it says 11 x 17 with no paper present. The sensors shouldn't see anything looking into the sky.
            • 22999
            If you do change the scanner board, you'll also need the CCD calibration charts. The color table is stored there. =^..^=
            • ntbann
              • Jan 2012
              • 627
              Yup just found my 3 charts. Thanks!
              • ntbann
                • Jan 2012
                • 627
                LEES thank you! It was actually the white plate was out of place and stuck.
