Vertical black lines..
  • mickeyc123
    • Apr 2013
    • 18
    [Electrical] Vertical black lines..
    Hello all,
    i have a UTAX 5555i (its the same as a Kyocera 5501i) giving vertical black lines randomly when printing.
    it has just over 1.8M on it and has recently had a new maintenance kit installed.
    Pic below,
    Ive cleaned the contacts and tried a new charge and drum. the machine could print 200 pages without issue but then put lines on the next 10 pages then disappear again.
    i suspect the high voltage power supply is causing the issue but wanted to ask in here to see if anyone one else has had a similar issue?
    thanks,
    mick
    • 23010
    Re: Vertical black lines..
    It looks like primary charge loss to me. See how the anomalous lines cross the edge voids? Not the laser. Is the interval 37.5mm? =^..^=
    • Ropariva
      • 695
      Check the drum earth. Plastic tab removed before fitting?
      • mickeyc123
        • Apr 2013
        • 18
        Depending on where I measure from the lines are between 40 and 45mm apart.
        • mickeyc123
          • Apr 2013
          • 18
          Yes, tab removed from back of the drum.
          Issue is random, could do 200 prints without a problem then put out 10 to 15 pages with lines.
          • kyogenius
            • Jul 2012
            • 136
            have had this very same problem on a 5500i .
            try this and see if it will solve your problem
            get into sim 100....turn AC auto adj OFF... chnge the AC BIAS to any value between 107-117 and check if it helps.One of our machines has been working fine after doing that.
            failure is not an option !
            • copiertec
              • Jan 2016
              • 2211
              We have used dialectric grease on some drum shafts to correct drum shorting issues on the old Alfard series.
              • JPazy
                • Jul 2019
                • 30
                I had one many moons ago having a similar problem. Would have sworn it was drum grounding or MC problem. Ended up being a problem with the DV unit. Replaced the developer unit and problem was solved.
                • KYO_OEM
                  • Aug 2011
                  • 726
                  Hi,
                  why you don`t follow UTAX bulletin TB-57S to solve it?
                  You also can use KYO bulletin 2N9-00009 (F180)
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    Originally posted by KYO_OEM
                    Hi,
                    Spot on. Great contribution.
                    • mickeyc123
                      • Apr 2013
                      • 18
                      Hi,
                      Wow, thanks very much for this kyo_oem!
                      I did not see that bulletin and it describes exactly the issue I'm having.
                      I'll give it a shot when I'm back in with the customer tomorrow.
                      Thanks again!
