mita Vi230 jam00
  • gordie
    • May 2008
    • 83
    mita Vi230 jam00
    Hi
    I have a mita Vi230 showing jam oo in the radf intermittently, I have found 3 sensors which I have cleaned with canned air. When you place an original in the radf and press for a copy it comes up jam 00 and it is difficult to reset, can anyone help? Advice , Service manual , engineers code and sub code to check the sensors.
    Thanx in anticipation
    Gordie
    sigpic
  • Funnyfarm69
    • Jun 2008
    • 51
    Hi Gordie, firstly you should change that flag to a red one with a canon on it!! 1-0 to the arsenal..
    When you blow the sensors out does the radf work at all?
    I would say that a sensor is sticking which makes it difficult to reset, have looked in the manual and cannot see much info on jam codes.
    Maybe a strip down jobbie.
    Does the code 00 come up in the display?
    The only radf jam codes i can find are...
    J070 No original feed
    J071 Jam in df original feed section 1
    J072 " " " " " 2
    It defo sounds like a faulty or stuck sensor.
    We had one with the same problem but we sent it up north!!!
    sigpic MINES A PINT!
    • gordie
      • May 2008
      • 83
      Hi
      Thanx for your reply, the least said about Newcastle the better! I did not renew my season ticket this year and am I pleased!
      It is a few days ago since I was at the machine as far as I can remember when you place an original in the radf it comes up jam 00 and I think it says paper jam in radf but the jam arrow lights up for the radf . when this happens I have moved all the sensor flags but the error will not clear. This is why I was hoping that there was the facility to test the sensors in the service mode but it is a bit difficult without a service manual..
      Regards gordie.
      Ps I know your team is a lot healthier than mine but yuors does not appear to be firing on all cylinders this season.
      sigpic
      • Funnyfarm69
        • Jun 2008
        • 51
        Hi mate, wait till we sign arshavin!!!!
        Go into maint mode (10871087) and check the switches with the following modes.
        Maintenance
        Description
        item No.
        U244 Checking the DF switches
        Description
        Displays the status of the respective switches in the optional SRDF.
        Purpose
        To check if respective switches in the optional SRDF operate correctly.
        Start
        1. Press the start key. The screen for selecting an item is displayed.
        2. Select the type of switches (SW or VR) to be checked using the
        cursor up/down keys.
        3. Press the start key. The screen for executing is displayed.
        Display
        SW
        VR
        Type of switches
        On/off switches
        Volume switch
        Method for the on/off switches
        1. Turn the respective switches on and off manually to check the status.
        If the on-status of a switch is detected, the corresponding switch is
        displayed in reverse.
        Display
        SET SW
        FEED SW
        REV SW
        TMG SW
        SZ A SW
        Switches
        Original set switch (OSSW)
        Original feed switch (OFSW)
        Original switchback switch (OSBSW)
        DF timing switch (DFTSW)
        Original size length switch (OSLSW)
        2. To return to the screen for selecting an item, press the stop/clear key.
        Good luck. Can email the manual if you wish.
        Michael Owen is on his way to the emirates.
        • gordie
          • May 2008
          • 83
          Hi, Thanx for the info I will go back to the customer and give this a go.
          I would greatly appreciate a copy of the service manual as I have no information on mita digital machines.
          gordie@bes13.freeserve.co.uk
          Maybe arshavin might be the missing link!
          Your welcome to Own his first priority is to play for England and the rest of the time he is on the sick. You can have kinnear as well. Sick as a parrot !!!!!
          Regards Gordie
          sigpic
          • Funnyfarm69
            • Jun 2008
            • 51
            Check your email.
            • gordie
              • May 2008
              • 83
              Hi Sorry to say I have not received your email
              Gordie
              sigpic
              • Funnyfarm69
                • Jun 2008
                • 51
                Maybe the file is too big for freeserve (4mb)
                do you have another email address to try?
                • gordie
                  • May 2008
                  • 83
                  Hi, have not been able to reply site down for a day.
                  No I do not have another email.
                  Is there anyway or ziping it or halfing the file?
                  Regards Gordie
                  sigpic
                  • Funnyfarm69
                    • Jun 2008
                    • 51
                    Sent as a zip this time, good luck.
                    • digicor
                      • Jul 2008
                      • 1159
                      the reset might work for this , i think its 906? in service mode
                      clears sc codes and resets.. might work, im going to a machine with the same prob tomorow ill post what does it.
