Kyocera 250ci Firmware - Latest
  • brecht2
    • Feb 2012
    • 71
    #16
    • KYO_OEM
      • Aug 2011
      • 715
      #17
      Re: Kyocera 250ci Firmware - Latest
      Sorry, all trashed....
      Current stock: 0
      Last pc sold in 2017-05
      • brecht2
        • Feb 2012
        • 71
        #18
        Hello,
        I've took the code dimm out of the machine and got this;
        • KYO_OEM
          • Aug 2011
          • 715
          #19
          it`s clear for me.
          System is loading the FW from USB key to memory and after download from key was completed, it tried to write to non existing code dimm.
          No target available ---> error message must coming up.
          Did you wait up to 30 minutes with mounted code dimm?
          Did your key led is flashing during "Welcome" message?
          • brecht2
            • Feb 2012
            • 71
            #20
            Did you wait up to 30 minutes with mounted code dimm? YES
            Did your key led is flashing during "Welcome" message? NO (read/write led) USB Stick is Kingston 4GB
            I'll order new code dimm on ebay. I saw one for 8.5€
            Shipping will take approx 2 weeks (COVID).
            I'll follow your advise to install the new code dimm and install it with the broken one.
            I'll reply to this thread as soon as the installation has been done.
            Thx!
            • brecht2
              • Feb 2012
              • 71
              #21
              Dear Kyo_oem,
              I'm was thinking why i have to swap the good code dimm with the bad one?
              Why i can't upgrade the FW with the good one without swapping this dimm?
              Could you explain this to me please?
              Kind regards
                • 16391
                #22
                There are a few guys on this site that I consider to be experts on Kyoceras and KYO is one of 'em. I don't even question him anymore...especially when it comes to firmware issues.
                • KYO_OEM
                  • Aug 2011
                  • 715
                  #23
                  this you can do if no new one available.
                  In your case you don`t need it.
                  Install the "ebay dimm" and hopefully it`s a well working one.
                  You`ll see it when LED is flashing on your Kingston during upgrade procedure.
                  Good luck
                  • dalewb74
                    • Feb 2018
                    • 1153
                    #24
                    Originally posted by Scott
                    RUN!!! it's a 250ci.... LOL
                    yes.... run fasttttttt...... lol
                    • brecht2
                      • Feb 2012
                      • 71
                      #25
                      I've bought this code dimm...
                      Kyocera Printer Memory Module A0219AME + GH | eBay
                      This dimm seems to be another review (newer than mine).
                      I'll keep you in touch after the installation!
                      grts
                      • KYO_OEM
                        • Aug 2011
                        • 715
                        #26
                        good luck.
                        • brecht2
                          • Feb 2012
                          • 71
                          #27
                          Hello KYO_OEM,
                          My ebay code dimm has been arrived and installed but no luck....
                          Screen is still stuck at the 'welcome' screen.
                          I've waited more than 1 hour.
                          I saw r/w on my usb flashing many times on booting, with the other code dimm i didn't saw anything at all.
                          I saw the led 1x flashing on the OP.
                          What i further did...
                          I've changed the dip switch on the mainboard of the OP to 'boot', started the machine and waited until the memory led stop flashing.
                          Changed the dip switch again to normal position.
                          Turned of the machine and tried again to update the F/W.
                          • KYO_OEM
                            • Aug 2011
                            • 715
                            #28
                            you got PM because i think it`s too difficult to explain further points in official forum.
                            Maybe you can get direct support
                            • tahitibub
                              • 4
                              #29
                              Originally posted by Jabberwocky
                              Got it working. Long ago I had written a software routine to "wrap" TLS 1.0 inside of a TLS 1.2 packet. I just needed to get the 250ci up to TLS anything. I got a hold of the firmware yesterday to upgrade it to 2016 and everything is working fine with Office 365 now. Thank you everyone!
                              Hi Jabberwocky,
                              I'm very interested with your software routine to "wrap" TLS 1.0 inside of a TLS 1.2 packet.
                              Could you please explain how did you do it ?
                              Regards
