C4600 TASKalfa 5052ci
  • dikyo
    • Apr 2011
    • 45
    Hi guys,
    I have a problem with a 5052ci
    When i switch on the machine, the machine starts up and after 15 a 20 sec. the machine gives error C4600.
    I already replaced:
    LSU (complete unit)
    flatcables LSU-Engine pwb
    engine pwb
    Main pwb.
    any suggestion would we welcome
    thanks in advance.
  • Firthy
    • Apr 2019
    • 20
    Re: C4600 TASKalfa 5052ci
    Have you replaced the motor?
    • copier tech
      • 8169
      Originally posted by dikyo
      Hi guys,
      I already replaced:
      LSU (complete unit)
      engine pwb
      Main pwb.
      thanks in advance.
      Did you update to the latest firmware version? currently Version: 04.04.0040 there are several corrective measures with this release.
      • kuby
        • Oct 2007
        • 1408
        What is your firmware version? The current version is 4.07.
        • KYO_OEM
          • Aug 2011
          • 720
          What happens if you set U474/ Cycle to "0" or "2000"?
          At the moment system reached the 1000 cycle and want`s to run the cleaning, maybe we can stop it and getting entrance to check the motor by U474.
          Please remember that at same connector we have the waste toner motor. Broken/ blocked waste motor and maybe no more 24V present for LSU cleaning.
          Have heard from 1 similar case in past.
          • dikyo
            • Apr 2011
            • 45
            Hi Guys,
            the cleaning motor is part of the LSU (is replaced)
            Firmware is 04.05.0030
            Settings in U474 has no effect.
            @KYO_OEM
            i will check the waste toner motor/24v
            thanks
            Grtz Dikyo
            • kuby
              • Oct 2007
              • 1408
              I would re-flash the firmware first. Sometimes it gets corrupt and can cause errors. Do the full install and not the Turbo, that way you get the whole package. I have seen corrupt firmware cause errors before and re-flashing it with the firmware Pack and not the Turbo Pack helped fix the problem. Worth a shot.
              Current version 4.07.
              • thecopyist
                • 6
                Has there been any resolution to this problem we're getting a C 4600 on a taskalfa 6052ci firmware updated whole LSU replaced whole engine board whole main board ribbon cables checked
                • sparkycivic
                  • Apr 2017
                  • 348
                  does the motor actually work?
                  Or is it a phantom fault?
                  • KYO_OEM
                    • Aug 2011
                    • 720
                    Have had C4600 because of broken waste toner motor!
                    Same connector YC27 on engine pwb.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      +1 had the same
                      Regards Mark
