Kyocera 306ci
  • CopyGSV
    • Nov 2019
    • 3
    Kyocera 306ci
    Copier will not allow prints. Default is set up for B&W Prints only but it is requesting Color Toner in order to allow them to print.
  • craigster
    • Apr 2016
    • 201
    Re: Kyocera 306ci
    In the system settings you need to enable print in black and white when color toner is out. Its in your operator guide
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1878
      Re: Kyocera 306ci
      Be careful when using this. It's a great idea, but very poorly executed by Kyocera.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
        • 23006
        Re: Kyocera 306ci
        Just install the color toner so it can calibrate. =^..^=
        • KYO_OEM
          • Aug 2011
          • 711
          Re: Kyocera 306ci
          Don`t forget the limitation for running in b/w mode.
          You can`t run b/w only!
          Pages allowed after color toner empty:
          A4 systems:
          Sirius 30 pages max.
          Mebius = 50 pages max.
          Perseus = 500 pages max.
          A3 systems:
          Jupiter I+II = 500 pages max.
          Venus I+II = 500 pages max.
          Iris I+II = 1000 pages max.
          Mercury I,II+III = 1000 pages max.
