Ecosys P6325
  • Larhal
    • 609
    [CQ] Ecosys P6325
    Hi All,
    We just picked up Kyocera Printers. I am Ricoh trained but had some experience (a little) with Kyocera products.
    We just placed 6 of the Ecosys P6325 printers in 4 different locations in January. I am getting CQ calls left and right. It seems that the toner, Original Kyocera, causing lines on the drums, like tear drops. This is happening mainly with the black but also is happening with the colors, not as much as they are not used as much. The clicks on the machines are between 7K and 11K.
    Have not gotten access to the Kyocera site as of yet. Are there any Service bulletins on this issue? Anyone else seeing this issue.
    Thanks in advance for any help.
    Larhal
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • 23010
    Re: Ecosys P6325
    Can you present some samples? =^..^=
    • scottybbb
      • Dec 2010
      • 126
      Re: Ecosys P6325
      They supposedly changed something with the drum unit. Changed the thickness of a spacer inside the unit itself. We still see this all the time with this series. Just got to change the drum and warranty the defective one.
      • Larhal
        • 609
        Re: Ecosys P6325
        Hi Scottybbb,
        that is what we have been doing, I carry 2 sets of drums now. Thanks for the information, are there any SB on this?
        I am going to a call today and will get pictures and post them Blackcat.
        Larhal
        Larhal
        • Larhal
          • 609
          Re: Ecosys P6325
          Hi All,
          We to a call this morning and found this.
          Needless to say 4 drum units to be replaced.
          Larhal
          Larhal
            • 23010
            Re: Ecosys P6325
            Yup. Kyocera spaced the drum blade closer to the drum for better cleaning. It must be working to some degree, because I'm not seeing the same machines repeatedly.
            If you're in a pinch, they will clean off with orange-sol or Fast505 and a lot of rubbing with webrils. Then a rinse with alcohol. =^..^=
            • scottybbb
              • Dec 2010
              • 126
              Re: Ecosys P6325
              There is a service bulletin from July of 2017. Reference number is 2NR-0036 {H139}. We still see the problem with new drum units.
              • Larhal
                • 609
                Re: Ecosys P6325
                Thanks all for your assistance. Great bunch of people you are.
                Knowledge is key and this forum has a lot of knowledge to share.
                Thanks again.
                Larhal
                Larhal
