m2540 jamming in fuser
  • cpuryear
    • Mar 2019
    • 15
    Anyone have experience with M2540 jamming in fuser. Replaced fuser. Still jamming about halfway out. A little further out sometimes. Thanks, Chris
    • 23006
    Re: m2540 jamming in fuser
    hmmm.
    Jam codes? =^..^=
    • KYO_OEM
      • Aug 2011
      • 712
      Take a look to I160_2S0_0023_SB.rev.3.pdf
      • cpuryear
        • Mar 2019
        • 15
        hmmm.
        Jam codes? =^..^=
        Code 4219
        • KYO_OEM
          • Aug 2011
          • 712
          If no J4211, only J4219
          Check Fig. 10 Paper Feed Section1/ #11/ Frame MPF/ 302RV08010
          Have seen a few pieces which are broken.
          • Scottb
            • Apr 2013
            • 306
            I had one that would evaporate the moisture out of the paper and it would condense above the fuser and caused a similar issue...but I don't' remember the code that it was giving
            • Santander
              • May 2009
              • 768
              If you replaced the fuser with a new updated fuser and not one from an existing unit, I agree with Kyo_OEM, check the drive gears in the fuser drive section as the tech bulletin illustrates. You could have a broken fuser drive gear.
