7551ci 11x17 crease
  • mntech
    • Aug 2010
    • 250
    7551ci 11x17 crease
    Getting a fuser crease the trailing half of the paper 11 x17, but only on bi-fold. If I run non folding single or duplex 11x17 they are fine.
    First sheet is always fine, then all others are creased. The books are only 1 page, and it seems to have something to do with the delay where the sheet will sit at duplex/reg until the previous sheet is folded, then starts feeding into to fuser.
    Hard stops shows crease happening in fuser, so it must be skewing into the fuser, but paper seems straight prior to fuser, but why only when doing bi-fold and not on non-folded duplex?
    Going to try a new right side door first.
    Thanks for any insight into this issue.
    -mntech
  • Mr Magic
    • Jan 2020
    • 29
    Re: 7551ci 11x17 crease
    Try updating the FW.
    • copydocinc
      • Mar 2015
      • 263
      You could be losing your buckle at the registration roller, due to slippage, while the page is waiting for the previous page to fold.
      If so, you might also notice a slight skew in the image on the 2nd side print.
      The slight skew could be causing the paper to enter the fuser skewed, causing the wrinkle.
      Maybe increase the buckle amount at the registration roller or see if the rollers holding the buckle need tension adjusted.
      • mntech
        • Aug 2010
        • 250
        Do you by chance know the u mode that would increase the buckle, I don't recall ever needing to make this adjustment on a kyocera. I could look it up if you don't recall.
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          -mntech
          Whats the Paper brand and weight. They do matter.
          Age of the machine, when the fuser was replaced last?
          Does the cassettes feed true? Does it skew a tiny bit? (cas 1 and 2 were known to be wonky, never able to tighten, and the skew adj did very little)
          Idling colour developers are not healthy developers.
          • mntech
            • Aug 2010
            • 250
            Fixed
            Thanks copydocinc,
            I set u051 duplex(L) from -11 to -6
            To increase the registration buckle on large paper being duplexed. Worked like a charm.
              bad advice
              firmware is NOT a fix all.
              he has a hardware problem.
              • Ropariva
                • 636
                Fixed
                Thanks copydocinc,
                Take out your feed units and check the four outer white rollers for tension Often there is none and the springs have to be stretched, but the biggest issue may be that the middle roller holder is likely worn from rotation of the roller shaft.
                • jmaister
                  certified scrub
                  • Aug 2010
                  • 755
                  Fixed
                  Thanks copydocinc,
                  Disclaimer: Maintenance value adj may fix something and introduce something else down the line.
                  • Mr Magic
                    • Jan 2020
                    • 29
                    Ok. Thanks for the update. Sometimes, FW can fix these sort of issues.
                    Nice one for identifying the cause.
                    • mntech
                      • Aug 2010
                      • 250
                      Thanks to everyone for all the help and feedback.
                      A couple side notes;
                      Problem was happening with both trays 1&2 so I don't think the feed stations were an issue.
                      Firmware was up to date.
                      The reg buckle adjustment I made would only affect larger size paper being duplexed, so I shouldn't see any issues with 8.5x11, but could cause problems down the road with 11x17 with other repairs.
                      Replacing the conveying unit would probably have fixed my issue without needing buckle adjustments, but I didn't have a spare to test with.
                      -mntech
