kyocera 1135mfp paper timing/registration adjustments
  • Tom
    • 344
    Does anyone know what the procedure is for making timing/registration adjustments to these machines? I've got a handful of 1128s in the field and with them it is a sim mode (34 I think) but on the 1135 there is a whole slew of sim adjustments that are missing. I quit putting out Kyocera desktops years ago cause I just don't like them, so I only have this one 1135. Don't see anything in the service manual either unless I'm missing it.
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: kyocera 1135mfp paper timing/registration adjustments
    SIMS can be added or removed with firmware updates so make sure you're at the latest. Also, if you experiencing varying registration I would recommend new feed rollers, especially the sep tire and after that the drive unit/clutch pack. DR-150 I believe.
    • GIUBOSS
      • 1436
      DR-150 for 1128 cod.302H493040
      For 1135 cod.302H994381. if have many prints, it is a good idea to first clean all the rubber rollers and sensors.
      • Tom
        • 344
        All rollers are new. The registration isn't reallly varying, I just want to adjust the timing a little bit so that her checks print better, needs to be moved a couple of mm to print a little higher above the line. If it wasn't for that she'd never even notice.
        • GIUBOSS
          • 1436
          I have seen in the manual that FRPO commands can be used to reprogram the firmware in which the values ​​can vary but I have never done so. Perhaps it is more convenient to edit the document to be printed
          • CWP
            • Jun 2013
            • 168
            Tom, to move the image up / down on the paper use the following FRPO command:
            !R! FRPO L2,XX;exit;
            Replace "XX" with a two digit number from 00 to 99. Smaller number raises the image, larger numbers lower it. The default is usually set to 50. If you need to move left / right it would be FRPO L4,XX.
            If you print a stat1 page you should be able to find the current settings on the second page I believe, may look something like 00/50/00/50.
            You can combine all commands into one and send to the machine with something like ICLink send file function. Here are all commands combined:
            !R! FRPO L2,50; FRPO L4,50; STAT1; EXIT;
            Can't remember on the 1135, but Kyocera's newer machine can take the command directly from a USB drive, just write your command into a text file with something like notepad and save it to the USB drive, then change the .txt name to .capt, insert it into the USB slot and print the file. Nothing will print (except the stat pages if called) but it will make the setting changes if done correctly.
              • 23009
              Good to know, Thanks. =^..^=
