kyocera 4050 fax issues
  • Tom
    • 344
    I have a weird problem with one of these. It will fax out and recieve, but it doesn't go through the first time. It rings, I hear it trying to connect, but then it never does and goes into wait mode. When it tries to resend the second time a couple minutes later it goes through just fine. It has the latest firmware and I tried swapping fax boards, didn't fix it. It's not the line cause I tested a different machine on it. Not a major issue cause they don't fax that often, but it's an inconvenience when they have to wait a few minutes for it to go through the second attempt.
    Re: kyocera 4050 fax issues
    is it on an analog line or other?
    can you post the settings sheet?
    have you monitored the line for noise?
    have you tried another tel line from wall to unit?
      • 30308
      Turn off the 33k baud modem
      • tsbservice
        Field tech
        • 8020
        May be bad line.
        It won't send receive at first time because of line errors. Second one in ECM it will pass.
        Another brand machine may fax at first attempt due to default error settings set to less strict.
        • Tom
          • 344
          Thanks, I'll give that a try. I was wondering if it might be a setting, I used to be pretty good at that but I've forgotten so much fax stuff, just don't have to deal with it that often and they rarely have problems anyway.
            • 30308
            Worst case turn down modem to 9600 baud rate
            • sostek
              • May 2010
              • 80
              Turn off ecm and set speed to 9600, these settings give the best oppurtunity for success when using digital lines. Faxes don't like packets,
              • dalewb74
                • Feb 2018
                • 1157
                can you fax to that same number from another machine with no issues?
                  • 23009
                  Sounds really familiar. How about this?:
                  Unable to memory Tx fax. "No Response", and busy indications. Fax relay clicks, then the status monitor briefly displays "Sending" (just a flicker, 1 second or less). No phone number is dialled, no dial tone, no sound from the line monitor. Manual Tx works fine.
                  Incorrect setting for PBx line. In simulation U660 Set Calls, Exchange, set from PSTN to PBx.
                  • Tom
                    • 344
                    Yea, that and one other setting fixed a problem I was having with an 1135 last month, probably why it sounds familiar. Different problem and machine this time, I can hear it call out and trying to connect, it just never picks up on the other end until the second try. I'll try reducing baud rate and turning off ecm next time I'm out there. Weird I had 2 back to back fax problems, it's almost always the line.
                      Are they from the same provider? If YES check with them.
                      • tmaged
                        Owner/Service Manager
                        • Oct 2008
                        • 1889
                        I use the VOIP settings that Kyocera has posted. Don't disable ECM. Also check the wire and make sure you're only using a 2 wire line.
                        Most of the new fax pwb's only utilize a two prong connector, so the 4 wire lines aren't an issue.
                        Hope that helps !
                        -Tony
                        www.dtios.com
                        Become a fan on Facebook
