TA 7052ci Error C9530 | 9540...
  • jqueen
    • Jul 2015
    • 56
    [Error Code] TA 7052ci Error C9530 | 9540...
    I'm directing this to Black Kat cause yeah....
    C9540 is Backup Data Error in service manual and that it is multiple pwb's replaced at the same time (practically a brand new machine and no units have been replaced) and C9530 is not even mentioned. Client states it is intermittent. Saw on a previous post from older model that "Contact the Service Administrative Division". Confusion, yes! Should I just do a 906 Error reset and wait watch for a bit or ????. Help please.
    And yes, I do come here quite often...just not always allowed to respond to problems in fear of getting in 'Trouble'....
    Thx for the assist.... -J
    • 23008
    Re: TA 7052ci Error C9530 | 9540...
    I certainly would do the U906 first, just in case it's a one-off (not going to happen again).
    If it comes back, I think I'd start by attempting to update the firmware. I say "attempting" because I don't think you'll be successful ... actually I hope that you aren't successful. The firmware that doesn't load is on the board that you'll need to replace.
    If it takes all of the firmware, and you can confirm all of the firmware levels in U019, then I think I'd start with page memory.
    Originally posted by jqueen
    ... And yes, I do come here quite often...just not always allowed to respond to problems in fear of getting in 'Trouble'....
    Who are you going to get in trouble with? Certainly noone here at Copytechnet.
    Let us know how it goes. =^..^=
    • jqueen
      • Jul 2015
      • 56
      Let us know how it goes. =^..^=[/QUOTE]
      I know its not here, on Copytechnet....its the BOSS...
      I will let you know how it goes. Thx for the insight.
      • tsbservice
        Field tech
        • 8013
        Wow, that's terrible queen. Nobody should even think fear to ask in plain space.
        Sounds like Boss is a member here. Mind you PM me?
        • jqueen
          • Jul 2015
          • 56
          UPDATE:
          On Thursday, went to EU's office. Cleared all codes, ran firmware.....ALL GOOD! Did 906. Okay for now.
          This morning, got email from EU....9530 again.......Any thoughts??? -J
          • Luther
            • May 2006
            • 682
            I would start reseating all the connections on all the boards, have had a lot of issues with poor connections on kyocera equipment
            • tmaged
              Owner/Service Manager
              • Oct 2008
              • 1885
              Have you got any input from Kyocera ? I think I would look at it as a C0680, as I believe that's where the data is backed up.
              Hope that helps !
              -Tony
              www.dtios.com
              Become a fan on Facebook
              • craigster
                • Apr 2016
                • 201
                Checked the Astea site not much there except older machines but all was pointing to engine pwb connections
                • jqueen
                  • Jul 2015
                  • 56
                  I wasn't on the phone with Kyocera. However, it was recommended from Kyocera that we replace boards. Didn't have to though...both Boss and I went to work on the copier and we reseated most of the connections and have not heard back from the EU since, 4/23.
                  • jqueen
                    • Jul 2015
                    • 56
                    Re-seating drum/dv unit connections and most of the connections that go to the main board and sub boards in the back. Haven't heard back since 4/23. Hope this helps those who run into this issue.... -J
                      • 23008
                      Thanks for answering back. Congratulations on your success. =^..^=
                      • KYO_OEM
                        • Aug 2011
                        • 714
                        Congratulations Jqueen
                        Good job!
                        C9530 means backup error for hidden sub pwb (called SUB PWB)
                        C9540 means backup error between engine pwb <--> main pwb
                        C9530:
                        SUB PWB: It`s the "brain" from each color system..storage device for serialnumber, systemtype, all counters, digital storage to prevent counterfeit notes, etc..
                        You don`t find any description for this pwb.
                        At newer systems sometimes located nearby power supply fan.
                        e.g.
                        TA 2552 CI/ engine pwb/ YC 38/ pin B1-B4
                        At your system/ engine pwb YC 20/ pin A17-A20 (see enclosed wiring, wiring visible up to the relay connector, picture from sub pwb missing)
                        As you can see in both cases, located at the edge from connector
                        C9540:
                        Mostly bad connection from FFC between main <--> engine pwb
                        Have had a few cases with both errors because of bad connected plugs from chinese factory! (i hate them...)
                        Also take a look to enclosed pdf file, i had send this file to field technician for checking. (TA 2552 ci/ C9530)
