TA3550ci C5101 error
  • dalewb74
    • Feb 2018
    • 1150
    need a bit of help with this one. i have updated the firmware using the turbo pack. was thinking about going back and update with the full firmware package. i have the service manual. which says main high voltage error K. and lists what should be done for a fix. i have replaced the K drum unit as a whole, which has the charge roller unit in it. cleared the count afterwards. but still get the error. customer has stated she can turn it off, wait about 10 seconds, turn it back on and it works fine for awhile. it might give the error again that day, or could be the next day, or whenever. she also stated it isn't used a whole lot. i know the service manual states about the high voltage pwb and engine pwb. just wanted to see if anyone has ran into this and found a fix. just hoping i might find something before jumping into replacing the boards. also see in the manual it says something about the br eject sensor non arrival jam, that the sensor doesn't turn on. that one i haven't tested anything yet. am i understanding that correctly that it could have something to do with the bridge unit exit as well? also says something about the paper feeding from each of the paper cassettes. input is appreciated, thanks.
  • Luther
    • May 2006
    • 682
    Re: TA3550ci C5101 error
    did you reset the charge roller count or the drum count? if not reset the charge roller count for the black drum u930, this happens if the count goes to far, the machine tries to compensate for the count
      • 23006
      Yes, the C5101 can occur if the U930 charge count has not been reset when the charge roller is replaced. Keep in mind that C5101 is not just for black, it is a primary charge leak on any color. You can get this error just from swapping around charge units of varying usage.
      Were it me, I'd replace all the main chargers before thinking about an HVT or Main board. =^..^=
      • GIUBOSS
        • 1431
        Small tip: Did you perform the calibration after the replacement? If the environment is a little damp (or paper) it can make bad jokes, in case it installs a drawer heater and activates the option.
