taskalfa 3500i
  • Gab
    • Aug 2015
    • 671
    taskalfa 3500i
    paper jam from 1st cassete fequently. It looks like it pulls paper about 1cm or less and stops. Open and close paper cassete and continous. MAchine mada about 160k copies . I cleaned feed rollers with no result.
  • Ropariva
    • 680
    Re: taskalfa 3500i
    Jam code?
    • GIUBOSS
      • 1436
      Re: taskalfa 3500i
      The technician's ABC says to check the PM counters of the paper feeds and replace them if necessary.
        Re: taskalfa 3500i
        Have you tried swapping the tyres between cassette 1 & 2
        • tsbservice
          Field tech
          • 8020
          Re: taskalfa 3500i
          Agree to all above answers. 160k probably most of top drawer. If machine use one ways in rollers drive check them also, rollers may look/be good but if one-way slips its shaft...
          • Gab
            • Aug 2015
            • 671
            Re: taskalfa 3500i
            Originally posted by Ropariva
            Jam code?
            jam code 1301
            The same with 2nd cassete
            • Alexkyocera
              • Jul 2015
              • 82
              Re: taskalfa 3500i
              Check retard roller
                Re: taskalfa 3500i
                There is a thread on a 5501 here I am not sure how similar these machines are though
                https://www.copytechnet.com/forums/k...37=#post513962
                  • 23009
                  Re: taskalfa 3500i
                  The feed units are a bit different ... not exchangeable. The higher speed models have an extra set of aligning rollers that can be an issue because of weak idler roller pressure. Those rollers do not exist on the lower speed models. =^..^=
                  • NeoMatrix
                    Senior Tech.
                    • 3513
                    Re: taskalfa 3500i
                    Have you recently installed other options like a finisher?
                    If so, try updating to the latest firmware....
                    HTH
                    • rvptor
                      • Aug 2018
                      • 19
                      Re: taskalfa 3500i
                      302N493030- feed drive, Change this
                      • JVergin
                        Service Tech / IT Rep
                        • 216
                        Re: taskalfa 3500i
                        Are you getting a jam code? or is it just showing a message something like "Cassette 1 problem. open and close cassette 1"?
                        I've found if it just shows that cassette problem message without a jam code, the paper tray is either over-filled, or the blue paper stop / sideguides are TOO tight. If the guides are too tight, it doesn't allow the paper to properly gradually lift as the paper is depleated. Opening and closing the cassette will temporarily fix the issue until it has trouble lifting the stack of paper again.
                        - Take the paper out and jog it. Make sure there's no bent corners/damaged paper.
                        - Reposition the sideguides and paper stop. Make sure the rear sideguide isn't broke and is straight. Sometimes it can jump teeth on one side and be crooked. Also make sure the paper hasn't cut into the sideguides so much that the paper is catching on it while lifting the stack.
                        - Replace the feed rollers. These rollers generally don't go past 150k without a problem, at least for my customers.
