Replacing TA 4501 w/ 4501 Will U917 Work ?
  • Doug James
    • Jan 2012
    • 935
    [Misc] Replacing TA 4501 w/ 4501 Will U917 Work ?
    Hi, I am replacing a TA 4501 with a TA 4501 (Machine has composite black that won't fuse and I couldn't fix on site ugh..). If I do a U917 to transfer all the data to the new machine going to enable the machine to Scan, Print etc without needing an IT guy to hook it up. Was wondering before I got into this mess... Thanks so much for any response !!!
  • copiertec
    • Jan 2016
    • 2207
    Re: Replacing TA 4501 w/ 4501 Will U917 Work ?
    Yes, that should work for the address book etc. Just assign the replacement machine with the same IP. Seems like a lot of work for a machine that will not fuse ink.
    • tmaged
      Owner/Service Manager
      • 1887
      Since you're going to the same model, you "should" be able to export network settings & everything.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Doug James
        • Jan 2012
        • 935
        This copier has been a pain in my rear. Even boosted the fuser up to 200 and it works but figured I needed to find the malfunction... Thinking a power supply type issue or something....
        • KYO_OEM
          • Aug 2011
          • 719
          Why you can`t fix it?
          Did you check last page coverage on service status page 1?
          Did you set "print gray with black toner only" to decrease the amount of color toner?
          Check last page coverage with new setting.
          Please check enclosed bulletin for correct imaging settings.
          Have had similar case in past with fixing problem by using composite colors.
          Before change from this setting i saw very high amount of color toner, with new setting the amount decreased dramatacilly and system was running well.
          • Doug James
            • Jan 2012
            • 935
            Sure do appreciate that... Customer is tired of me trying to fix it so fixing it in my shop... I am going to go from there and let you know how it comes out. Thanks again !!
            • Copierstud
              • Nov 2019
              • 38
              4501 is a b/w copier kyo.
              • Doug James
                • Jan 2012
                • 935
                OH CRAP !! I meant 4551ci (Sometimes I wonder if my brain is all together ugh....)
                  • 23008
                  You'll be able to transfer quite a lot of the user data, but you'll find that the job accounting does not transfer, since there are color permissions required. My suggestion is to take each backup file separately. Then try to import them separately. You'll get most of the user data. =^..^=
                  • KYO_OEM
                    • Aug 2011
                    • 719
                    This was clear for me, but Gaia systems can`t print in composite mode....
                    Sometimes you must read between the lines, to see exactly what it is talking about....
                    In my job i receive a lot of requests, where i must do this for understanding what`s the problem on the other side.
                    Did you ever talk to indian or malaysien guys regarding problems???
                    Do it and you`ll understand.
