Ecosys M5526cdw
  • jrob416
    • May 2011
    • 112
    [Jamming] Ecosys M5526cdw
    I have a M5526 that gives a constant Jam 4211. Paper exits fuser and crashes into exit/eject unit and stop, z folding at above fuser. When jam is removed, there is no image on paper(printing from Reports). Machine has only passed around 400 pages. I have also noticed that there are no actuators on the exit unit. On other M5526 we have out, I have seen 3 flaps attached to a shaft hanging down that the paper pushes up when exiting into tray. Is this an issue with the Main PWB? I see nothing wrong mechanically.
  • rapidocument
    Multibrands Tech
    • Jul 2012
    • 381
    Re: Ecosys M5526cdw
    Try to crash the copier (open side door while copying) in order to see if the Z folding is present before the paper reaches the fuser, if it is then check for and sticky registration actuator or a bad registration clutch (I've seen energized clutches passing paper early or late and z folding it, the machine doesn't synchronize to print anything and the result is z folded, jammed and blank pages.
    My INSTAGRAM https://www.instagram.com/reparacion_impresoras_oaxaca
    • kuby
      • Oct 2007
      • 1411
      Re: Ecosys M5526cdw
      Check Eject sensor (ES)
      Eject sensor (ES) does not turn off during paper feed from cassette 1.
      Eject sensor (ES) does not turn off during paper feed from cassette 2.
      Eject sensor (ES) does not turn off during paper feed from duplex section.
      Eject sensor (ES) does not turn off during paper feed from MP tray.
      Look at page 3-2 of the service manual Item # 5. Eject sensor.
      The sensor is on top of the fuser unit. pg 3-41
      • Luther
        • May 2006
        • 682
        Re: Ecosys M5526cdw
        replace the fuser there was a change made to it for exit jams
        • KYO_OEM
          • Aug 2011
          • 725
          Re: Ecosys M5526cdw
          At Sirius Range take care for clutches.
          If you get z-folding and no image, i think your registration clutch is rusted...(302NR94010)
          • kuby
            • Oct 2007
            • 1411
            Re: Ecosys M5526cdw
            The sensor actuator is on top of the fuser unit. pg 3-41
            • jrob416
              • May 2011
              • 112
              Re: Ecosys M5526cdw
              The fuser passes the paper through. Page is found on top of fuser, not passing out to exit tray.
              • rapidocument
                Multibrands Tech
                • Jul 2012
                • 381
                Re: Ecosys M5526cdw
                Yes, the paper stops mid fuser because the machine detects a timing issue,
                the timing problem started in the registration clutch,
                Have you already checked the clutch (dissasembled it to see if its rusty?)
                Are you a tech or not?
                • jrob416
                  • May 2011
                  • 112
                  Re: Ecosys M5526cdw
                  Have seen it several times. [ATTACH=CONFIG]46483[/ATTACH]
                  Thank you. It was the clutch. I did not think that after 304 total pages the clutch would be fouled up. Took a little 600 grit cleaning paper to it and now all is fine. Thanks again.
                  • KYO_OEM
                    • Aug 2011
                    • 725
                    Re: Ecosys M5526cdw
                    it`s related to the storage position on the ship.
                    Shipping from from China factory to America will take a few month.
                    If the container is located in the upper area from the ship, they get rusted.....
                    KDC tries to find a solution against it, but until yet they don`t find a final solution.
                    It`s a well known problem for me since Alphard range.
                    Maybe you remember J4401/ 4411: brand you systems out of the box with duplex jamming.
                    Take care for e.g. 302NR94010/ clutch
                    This clutch also mounted in DP feed sections, you`ll find it in Perseus range and other models color + b/w.
                    Btut also other clutches getting same problem
                    • ntbann
                      • Jan 2012
                      • 631
                      Re: Ecosys M5526cdw
                      Thats strange. Sharp machines are shipped from China and have never seen one rusted clutch. Must be Kyo shit steel!
