2553ci
  • T911
    • Jun 2007
    • 628
    2553ci
    Anyone know how to default a tray for incoming faxes on this one I don't see it in system menu anywhere. Thank you
    • 22997
    Re: 2553ci
    If it's like the previous Kyoceras, you designate a specific media type for faxes. Then set the desired tray for that media type.
    **Remember** You cannot hard set the paper size for the tray that faxes are printed from. It MUST be set to Standard, Auto Detect.
    • KYO_OEM
      • Aug 2011
      • 709
      Re: 2553ci
      did you tried Quick Setup Wizard for Fax?
      2552ci have had similar issue at frist, would solved by FW upgrade.
      Don`t have system with inbuilt fax and diff. trays at the moment for testing.
      • Techboy
        • Dec 2014
        • 13
        Re: 2553ci I just set the paper type to Plain on every set up
        At set up I set the paper type to plain, 1 ring instead of two
        • nathicana
          • Aug 2008
          • 329
          Re: 2553ci
          system menu - common settings - paper output - fax
            Re: 2553ci
            You can find all of that information in the User Manual.
            TASKalfa 2553ci Documentation Download Center | ServiceWorld | KYOCERA Document Solutions
              • 29913
              Re: 2553ci
              Yes you can if auto reduce and enlarge is turned on.
              • KYO_OEM
                • Aug 2011
                • 709
                Re: 2553ci
                @bsm2
                It don`t work with fixed paper size( just tried)
                @all
                maybe there is a totally other problem behind.
                If no additionell tray installed you don`t get the possibilty to "select output tray"
                Mistakenly technicians are thinking that the upper tray inside will be selectable for paper out put.
                It`s no Job Separator it`s only for duplex paper feeding.
                Only in case of installed JS-7100, AK unit or finisher you get the possibilty to select out put trays.
                If mistakenly U211/ JS would set to "ON" without installed JS-7100, green job separator LED will be always on but you can t select this tray for output.
                  • 22997
                  Re: 2553ci
                  Did I misread the original thread? I thought the poster wanted faxes to go onto a specific paper ... not to go to a specific output tray.
                  I think that was unclear in the original post. =^..^=
                  • KYO_OEM
                    • Aug 2011
                    • 709
                    Re: 2553ci
                    "How to default a tray for incoming faxes"
                    Not a paper, or media type....
                    I think it`s clear..
                    @blackcat4866
                    In your first reply you explained the right way....
                      Re: 2553ci
                      @blackcat4866
                      Yeah, but what kind of tray? Output or paper? I thought he was talking about paper tray. You can set the default tray or output tray. Or both. The only thing is that you set the default paper tray by selecting the media type. He probably didn't know that.
                      • KYO_OEM
                        • Aug 2011
                        • 709
                        Re: 2553ci
                        This was the reason why i had written:
                        Try "Quick setup wizard".
                        By #5/ Output, you can select media type for fax and paper output.
                        But if no additionel tray installed, you can`t select any output tray.
                        Maybe you remember bulletin for Iris 1/ FW V3.00:
                        Up to this FW version it was not possible to select other output tray. You must use the quick setup wizard to get the possibilty to select JS tray.
                        (I coudn`t test on Iris 2 if we have the same problem, because we don`t have additionally tray installed at our Iris 2 with fax inbuilt.)
