kyocera 305 adf issue
  • dalewb74
    • Feb 2018
    • 1153
    if i copy anything from the adf it comes out blank. if i lay it on the glass it copies fine. i have opened the adf and checked for obstructions in the paper path. fed a thin piece of cardboard through the path and it came out without any issue. i also hit the path with some air in case of staples, paper clips, or paper dust. there are no errors messages. i am looking in the service manual and tech bulletins for answers. was just hoping someone might have seem this issue before and has a fix. guess i should give the firmware an update as well just in case.
    • 23008
    Re: kyocera 305 adf issue
    Is the scanner lock preventing the scanner from reaching the slit glass? =^..^=
