Unused Taskalfa 250ci prints horizontal lines
  • CarloMarchioro
    • Nov 2020
    • 6
    Hi!
    I bought a used Taskalfa 250ci few days ago, the office that sold it hadn't used it for about 6 months, the printer was working perfectly and regularly serviced.
    When I tested the printer I found that it prints repeating horizontal lines - yellow-black-magenta-cyan - - yellow-black-magenta-cyan.
    I assumed it was just dirty and would automatically clean itself with use, but it didn't.
    Do you have any advice on what the problem may be? I thought of a roller on which sediment has formed, but before taking the printer apart I wanted to ask someone more experienced than me.
    This is the scan of a blank print:
    • 16416
    Re: Unused Taskalfa 250ci prints horizontal lines
    We need to see some test prints of the problem you describe. Also, if they're repeating lines, you need to measure the distance between and tell us what that is. Thanks.
      • 23009
      What interval does the cyan mark repeat at? Try printing these images:
      A che intervallo si ripete il segno ciano? Prova a stampare queste immagini:
      • CarloMarchioro
        • Nov 2020
        • 6
        Thanks for the reply, Monday I make other prints and add them to the one already posted:
        https://www.copytechnet.com/forums/a...s-jpg-0001-jpg
        • CarloMarchioro
          • Nov 2020
          • 6
          Thank you so much for your reply, Monday I print the PDF file.
          • CarloMarchioro
            • Nov 2020
            • 6
            Done! Printed and scanned.
            doc20201130090852.pdf
            This is with a blank print, where the lines are more visible:
            • Drivee
              • Nov 2020
              • 322
              Lines are from OPC's. Cartridges are OK it is just bad printer. Did you try simple calibration?
                • 16416
                [ATTACH]47450[/ATTACH]
                You still need to measure the distance between the repeating lines and tell us what that is. I'm guessing it's the drum but I'd rather not guess if at all possible.
                • CarloMarchioro
                  • Nov 2020
                  • 6
                  Each line is exactly 9.65cm from the previous or next line of the same color.
                  Black <-9.65cm-> Black
                  Magenta <-9.65cm-> Magenta
                  etc.
                  As I said, the printer was in perfect, it still unused for about 6 months (or more) and when we turned on it started giving this problem.
                  Could it be sediment on the 4 drums?
                  • CarloMarchioro
                    • Nov 2020
                    • 6
                    Done :-/ same result.
                    I think it's a drum problem
                    • GIUBOSS
                      • 1436
                      check and clean the 4 Main Charge Corona Assembly
                      • Necrocannibal
                        • May 2008
                        • 212
                        It is the drums, those had a tendency for the transfer belt to scratch the drums. I think what happens is the belt sticks to the drums after sitting and when it gets turned on it scratches them, I have replaced numerous drums for this on those.
                          • 23009
                          etc.
                          Definitely drums. I'm guessing that the drum cleaning blade adhered to each drum during the storage period. The machine broke them loose, leaving residue from the neoprene drum blade. There is a very small chance that the residue may be cleaned off of the drum with a cotton pad and paraffin lamp oil, then alcohol.
                          • Necrocannibal
                            • May 2008
                            • 212
                            Never thought about the blade sticking to it but I bet you are correct and that is what it is.
                            Sent from my SM-N986U using Tapatalk
                            • Scott
                              • 196
                              It's the drums, when the unit sits for a while the drum blades get stuck to the drum. The only fix is 1 take each out and clean with denatured alcohol (you will see defect on drum) be careful and patient. 2 replace drums (if still available) I have seen this many times.
                              Scott
