Kyocera 4551ci - wide white band on black only
    • 16416
    I have a Kyocera 4551ci. All the colors look good except black. There's a wide white band 13mm wide. I've replaced drum, PCR and developer. Kinda of at a loss. Any help is appreciated. See examples below.
    Re: Kyocera 4551ci - wide white band on black only
    [ATTACH=CONFIG]47454[/ATTACH]
    print or copy?
    did you clean the optics?
    is scan lamp back at HP?
    how many pages on PM parts?
      • 16416
      print or copy?
      The examples I posted are the internal color test charts. It's only doing it on black and the K drum, DV unit and PCR are new. Just installed. I'm thinking it may be the laser slit glass but I'm not sure how to clean it. I'm looking for it in the manual. Don't see it yet.
        • 16416
        Okay, I see how to clean the laser slit glass. I'll give that a try tomorrow. Still, if anyone has any idea of what the problem is, please let me know.
          Black laser polygon mirror?
            • 16416
            I don't know. This is about the only area of this model that I've never had to mess with. I'm hoping it's just a dirty laser slit glass.
            • tsbservice
              Field tech
              • 8020
              Something is obstructing laser path. You have to find what. Maybe a some debris or piece of paper or even dead cockroach.
              • copier tech
                • 8172
                If this was fed SEF it looks like the laser cleaner is stuck?
                • tsbservice
                  Field tech
                  • 8020
                  It's parallel to paper path, Billy marked it so I guess your suggestion is even more valid than mine.
                    • 16416
                    Could be. I'll be at their office bright and early in the morning. It's easy enough to remove the metal cover over the slit glass where the laser cleaner arm resides. For good measure, I just uninstalled the laser unit from a machine in the shop. I had never done that before. Wasn't that bad.
                      • 16416
                      You're probably right. I thought it was strange that the the void area had well defined edges. If it was a dead roach or some other obstruction, it wouldn't be so precise of a void area. I'll bet you that the cleaning pad is exactly the width of that white band. I think you nailed it. We'll find out tomorrow.
                      • Ropariva
                        • 680
                          • 23009
                          +1 on the stalled laser slit glass cleaner. IIRC the cleaner is part of the laser unit itself, and not purchasable separately. You will need to entirely remove the laser unit to repair or replace this.
                          The thing to watch for when your manually driving the cleaner through its travel, is that when it reaches the end of it's travel there is some spring pressure holding the cleaner against the threads. If the spring pressure is inadequate the cleaner will cross-thread and jam or never catch and stall at the end. I have stretched those springs a bit, to make sure they're pressing back at the end of the travel. Also clean as much dirt out of the worm and use white grease to lubricate it.
                          I know it's counter-intuitive to grease it when the grease can collect dirt, but it does need the grease. =^..^=
                            • 16416
                            I don't think I've ever had a problem with a machine that someone didn't have the answer to. Let's keep the streak going.
                              • 23009
                              Is it a particularly dirty environment? =^..^=
