Kyocera ci problem
    • 30306
    Re: Kyocera ci problem
    Certainly.
    The clue was the ipaddress did not CHANGE after setting to DHCP.
    No worries it's fixed.
    Is machine on a surge suppressor? thats includes Network?
      • 16416
      Originally posted by Santander
      After you changed the unit to DHCP did you power cycle the machine? Changes to the network only take effect after a reboot.
      Yes, I'm aware of that and I did cycle the machine. I'm not sure what was going on with the machine but NOTHING worked until I ran U021 and it was like magic.
        • 30306
        If you have access download the prescribe manual and iclink tool.
          • 16416
          #19
          I'm not an authorized dealer. I'm an independent out here in the wilderness. Thank God for this site.
            • 30306
            #20
            Almost never have to use prescribe commands maybe 5 times in 40 years.
            Most likely iclink would not work if the card was frozen.
            KYOCERA Nic cards very rarely fail.
            Usually it's a lighting strike.
              • 30306
              #21
              Also you should update the firmware to the lastest level if it's not already.
                • 16416
                #22
                Also you should update the firmware if needed.
                The firmware is up to date. This is the first time I've seen this problem and hopefully the last. I've gotta go back tomorrow and set up SMB scan again because U021 wiped it.
                  • 30306
                  #23
                  Don't think I ever ran a U21
                    • 30306
                    #24
                      • 16416
                      #25
                      Thanks to a little help (he basically held my hand and walked me through it. ) from blackcat I sent my first prescribe command and it worked.
                      Side Note: In my head I had built up Prescribe as the 500lb. guerilla in the room but that couldn't be further from the truth. As long as you use the LPR Jar method, enable Java and save the command in notepad as a txt document, you're golden.
                      Thanks for all your help blackcat. Much appreciated.
                        • 30306
                        #26
                        You can also type in direct in iclink.
                        You can also really really screw up a machine should you start playing with margins etc...
                        99.99 never adjust unless Hotline or Tech rep tells you.
                        The problem is elsewhere. IE clutch etc...
                        You can also do some special features
                        as we replaced a dot matrix printer
                        we set it up to make copies 4 copies using 4 different paper trays. Pretty cool
                          • 16416
                          #27
                          That does sound pretty cool. Now that I know how to use prescribe, I'll keep learning how to do more stuff. This is one of those things that might not be needed often but when you need it, you really need it. I really needed it yesterday before I ran U021. lol
                            • 30306
                            #28
                            Hard to say dont think iclink would have work if Nic card was frozen.
                            Only have use iclink a handful of times in the past.
                            Older Kyocera models you could change some parameters through the web page.
                              • 16416
                              #29
                              blackcat mentioned ICLINK but said it was mostly unsuccessful. The Jar Method is simple enough and it seems reliable.
                              He also mentioned that I can send a data capture to the printer and it will print without a print driver. That's next on the list.
                                • 23009
                                #30
                                If you have a Kyocera printer in the office to play with, you'll find a few data captures in the folder with the utility.
                                I did throw in an excess of detail ... like usual. One last comment: Don't get creative with the command syntax. An extra period or an extra space will screw up the whole thing. Keep it simple.
                                Congratulations on your success. =^..^=
