Kyocera 6525 F245 error
    • 23008
    #16
    Re: Kyocera 6525 F245 error
    I'm sure that those manuals are for something ... remind me again? =^..^=
    • tsbservice
      Field tech
      • 8016
      #17
      I normally read them before make something stupid.
        • 23008
        #18
        I usually do a quick scan through, do the stupid thing, then go back and read more carefully. =^..^=
        • tsbservice
          Field tech
          • 8016
          #19
          One fundamental thing I learned long time ago. When you're in a rush making stupid things is unavoidably and as far as I'm concerned will pass this option to faster guys
          • copier tech
            • 8144
            #20
            Technology is so reliable now its very rare I will need to replace a board. This applies to pretty much all manufactures.
            Many inexperienced techs will see an error, check the service manual (which is the correct step) but this often will advice to replace a board over firmware etc.
