Taska alfa 300i firmware error
  • robikan africa
    • Sep 2008
    • 38
    [Dead] Taska alfa 300i firmware error
    Hi guys. I have a taska alfa 300i which was showing welcome on the screen. I changed the main, engine and operation panel board.and on upgrading the firmware it goes all through the process and completes . But when i boot up the machine after firmware upgrade its stuck on "restoring data in the Hdd this may cause a delay". Please help
  • copier tech
    • 8176
    Re: Taska alfa 300i firmware error
    Put all the original board back on the machine & update the firmware but first remove the SKIP file.
    • robikan africa
      • Sep 2008
      • 38
      Thanks for the reply . but with the original boards the machine does not pick the firmware. Its gets stuck on the welcome screen. many thanks
        • 23009
        Unless you've had a catastrophic event, like a lightening strike, it's very unlikely that all the boards are blown simultaneously.
        Start with original boards. Install (1) new board, Test. If no luck, re-install the original board, then try different board. Your shotgun approach is costly and not particularly effective. =^..^=
        • robikan africa
          • Sep 2008
          • 38
          Thanks for the reply black cat. I actually did a swap of the original panel on another machine but it still gave me the welcome screen and for the main board it does not perform boot up sequence on the machine..
          I will redo it like you have advised one board at a time.many thanks and I will revert.
          • tsbservice
            Field tech
            • 8020
            Review this thread and especially last post:
            Kyocera TA 300i
            • robikan africa
              • Sep 2008
              • 38
              hi . i did as advise on the boards one by one but still i get this restoring data in hdd. This may cause a delay. am curious though assuming i got all the 3 boards defective does it mean i cant get new boards/dimms and get this machine working again? do i have to rely on the original boards for the machine to work?
              many thanks.
              • robikan africa
                • Sep 2008
                • 38
                hi i dont seem to see skip file. am running out of ideas
                the original panel and main board are not working at all
                many thanks
                • mita
                  • Sep 2010
                  • 87
                  TASKalfa 300i stuck on "WELCOME"
                  • robikan africa
                    • Sep 2008
                    • 38
                    thanks the matter was resolved. machine okay and well
                    • tsbservice
                      Field tech
                      • 8020
                      Mind you share resolution?
