tasc alpha 4501i all paper drawers are working
  • digicor
    • Jul 2008
    • 1153
    the client says the machine is not working, i go and see that "all" the paper drawers are not functioning, not even the LCT okay i find paper behind drawer two crammed in the riser motor but not anywhere else, i re boot the machine, and still "all" the paper drawers are not functioning.
    why would all the paper drawers mal function if just one had paper behind it? is there a re-set? in service mode? im not familiar with this model enough to have that on hand, im a ricoh KMinolta guy, any help would be appreciated thank you
    • 16374
    Re: tasc alpha 4501i all paper drawers are working
    What are the error codes?
    When you say that all drawers aren't working, what do you mean exactly? The machine isn't recognizing them or they just won't lift?
    • digicor
      • Jul 2008
      • 1153
      no error codes they just wont lift
        • 16374
        Have you checked to see if you're getting voltage to the lift motors? But I would think that would throw a code. Check to make sure.
        Also, run U906 and see if that clears the problem.
        • kuby
          • Oct 2007
          • 1396
          Yes the reset in service mode for a disabled function is U906.
          • sparkycivic
            • Apr 2017
            • 348
            When cassette errors are counted consecutively, they become locked-out and must be reset in maintenance mode (u906).
            The errors will be recorded in the Event Log which can be printed(maintenance mode (u000), and it will lead you toward the original conditions that locked out the cassettes.
            • digicor
              • Jul 2008
              • 1153
              Thanks for all the help,
              i did the U906 all are working except LCT, as usual, it was being used as storage,, !! so its been probably not working for a while, school teachers office,,, anyway unlike a ricoh or minota the drawers all go out if one fails? okay
              ill remember this, Thanks all for the input
              • sparkycivic
                • Apr 2017
                • 348
                The lockout should only apply to the specific tray that is malfunctioning. That event log probably has quite a story to tell!
                • digicor
                  • Jul 2008
                  • 1153
                  yeah i guess it would... i find all kinds of things in the LCT and i make my speech about it not bing a storage unit,,,but i guess i dont speak very good English... when it runs out they dont re fill it and then its a nice little storage unit....
                  teacher,,....
                    • 23003
                    If the LCF is over-filled with paper, the excess paper will stall the PF motor and trigger a C26?? code, which isolates all the trays. It would help to look at the error log. =^..^=
                      • 16374
                      Can I come follow you around for a few weeks...for training purposes?
                        • 23003
                        I would be honored.
                        If I can paraphrase a quote from "Groundhog Day", Bill Murray says something like: "Maybe God isn't omniscient ... maybe he's just been around a really long time."
                        I make no claims to being a god or god-like, but I think he expresses it quite nicely. =^..^=
                          • 16374
                          I would be honored.
                          If I can paraphrase a quote from "Groundhog Day", Bill Murray say something like: "Maybe God isn't omniscient ... maybe he's just been around a really long time."
                          I don't think you're God, but almost daily I think you set the standard of where I want to be. No joke.
                            • 23003
                            You figure out how, and I'm in. =^..^=
                            • digicor
                              • Jul 2008
                              • 1153
                              okay thanks
                              when i did the u906 re set would it have re initialized the LCT? just asking
