Roller Cleaning
  • pperry
    • Feb 2021
    • 7
    [Misc] Roller Cleaning
    Hello Everyone,
    I've found multiple posts about roller cleaning, but the newest one that I found was from 2015. I'm wondering if I can get some updated suggestions on what to use to clean the grey rubber rollers on Kyocera MFPs. I know that alcohol will damage, them, and I've seen water used, but does it matter whether it is tap water, distilled water, etc.?
    Thank You for your help.
    Re: Roller Cleaning
    Originally posted by pperry
    Hello Everyone,
    I use rubber rejuvenator
    • pperry
      • Feb 2021
      • 7
      Re: Roller Cleaning
      Is that just a type, or the brand name?
        • 8132
        Re: Roller Cleaning
        Hello Everyone,
        Anything they removes the white paper pulp & turns them grey again
        However they cost peanuts so simply replace with new.
        • jhalfhide
          • Apr 2015
          • 451
          Re: Roller Cleaning
          Platenclene rubber restorer
          AF INTERNATIONAL PCL100
          Sent from my LYA-L09 using Tapatalk
            • 16310
            Re: Roller Cleaning
            What type of rubber rollers are we talking about?
            • pperry
              • Feb 2021
              • 7
              Re: Roller Cleaning
              The grey paper feed rollers going from cassette to the rest of the MFP. Kyocera KM-5050
                • 16310
                Re: Roller Cleaning
                In that case, I agree with copier tech, just replace them. If you need to clean and alcohol is damaging them, I'd suggest diluting with distilled water - 50/50.
                • pperry
                  • Feb 2021
                  • 7
                  Re: Roller Cleaning
                  Where would everyone suggest that I order them from? I'm probably going to have to use a source that will take a PO. I'm new to this schools system, so I'm not sure on all of the policies, when it comes to ordering supplies.
                    • 16310
                    Re: Roller Cleaning
                    You should be able to find here: Kyocera TASKalfa 3051ci Paper Feed Components
                    PS - Search for you model on the left of the screen.
                      • 8132
                      Re: Roller Cleaning
                      We can supply these.
                      How many sets do you need?
                      Firmware Update - Printer & Copier Firmware
                      • Scottb
                        • Apr 2013
                        • 303
                        Re: Roller Cleaning
                        WD-40 is a good temporary fix and is easy to find...you will need to replace the rollers eventually though like when using rubber rejuvenator
                          • 8132
                          Re: Roller Cleaning
                          Yes I use WD-40 on ALL rollers works a treat for me.
                          Now I KNOW others will disagree.......
                            • 22999
                            Re: Roller Cleaning
                            As far as I'm concerned it's the only good use for WD40, but only on rollers that are mostly beyond saving. For rollers with a little life remaining I use an orange oil based cleaner like:
                            NEW GALLON DE-SOLV-IT PROFESSIONAL STRENGTH CONTRACTOR SOLVENT CLEANER 9777210 74576101515 | eBay
                            • jhalfhide
                              • Apr 2015
                              • 451
                              Re: Roller Cleaning
                              Never thought to use WD40, but it is an amazing cleaner. In fact, it's what it's best at. Gets used thoroughly when cleaning my motorbike, and dirt and grease just drop right off.
