Roller Cleaning
    • 8196
    Re: Roller Cleaning
    Originally posted by jhalfhide
    Never thought to use WD40, but it is an amazing cleaner. In fact, it's what it's best at. Gets used thoroughly when cleaning my motorbike, and dirt and grease just drop right off.
    Sent from my LYA-L09 using Tapatalk
    WD-40 works the same as rubber rejuvenator.
    • pperry
      • Feb 2021
      • 7
      Re: Roller Cleaning
      We can supply these.
      How many sets do you need?
      Firmware Update - Printer & Copier Firmware
      Right now, I'm just looking to clean them. They don't look like they need to be replaced yet, but I know that they will get there.
        • 16462
        Re: Roller Cleaning
        It wouldn't be a bad idea to keep some PF rollers on hand.
        • pperry
          • Feb 2021
          • 7
          #19
          Re: Roller Cleaning
          I'm working on getting them to order spare parts for me, but its a long process.
          • jper34
            • Sep 2011
            • 225
            #20
            Re: Roller Cleaning
            I've used alcohol to clean the rubber rollers, then dampen my rag with tri-flo oil(could even use wd-40), wait a few minutes,wipe off any excess oil, give a couple minutes for oil to absorb into the rubber, it works great for me..I figure oil and rubber, are pretty much the same.Also softens the rubber, make it grab a little more, till you replace the rollers..
            Good Luck..
            Jaime P.
            Indep. Copier Svc.
            • Tonerkiller
              • Oct 2012
              • 669
              #21
              Re: Roller Cleaning
              I use simple green on syn, transport, and feed rollers.
              • Scottb
                • Apr 2013
                • 308
                #22
                Re: Roller Cleaning
                liquid hand soap works well also either diluted or just straight out of the pump.
                • pperry
                  • Feb 2021
                  • 7
                  #23
                  Re: Roller Cleaning
                  I would like to thank everyone for their help and input.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    #24
                    Re: Roller Cleaning
                    Hello Everyone,
                    I've found multiple posts about roller cleaning, but the newest one that I found was from 2015. I'm wondering if I can get some updated suggestions on what to use to clean the grey rubber rollers on Kyocera MFPs. I know that alcohol will damage, them, and I've seen water used, but does it matter whether it is tap water, distilled water, etc.?
                    Thank You for your help.
                    On the black charge rollers I find water better solvents
                    Regards Mark
                    • daveh12
                      • Jul 2012
                      • 157
                      #25
                      Re: Roller Cleaning
                      Use Rubber Re-Nu. Doesn't dry out and cleans perfectly.
                        Re: Roller Cleaning
                        I clean mine with NU Finish car polish works great
                          Re: Roller Cleaning
                          Apply a light coat of Nu Finish buff off after dry.
                          Might take a few applications, but the PCR roller will be shiny, and it produces a bolder print and doesn't build up as fast and there is less wear on the drum.
                          It works on mono and color PCRs.
                          • Jack79
                            • Jul 2014
                            • 312
                            #28
                            Re: Roller Cleaning
                            What would you suggest to use on transfer belt drive roller (located under/inside the ITB sleeve)?
                              • 23010
                              #29
                              Re: Roller Cleaning
                              I would use an orange oil based solvent. This is a relatively common complaint on the Toshiba eS 4505AC family for a theramin-like keening sound. =^..^=
