C2790 - 3551ci
  • tsbservice
    Field tech
    • 8020
    #46
    Re: C2790 - 3551ci
    Here's my latest problem on this damn machine. I tried updating the firmware after replacing the latest Control PWB and I'm getting the following error":
    IH Error 0801
    Any ideas?
    TA-3551ci: C6950 error code
      • 16416
      #47
      Re: C2790 - 3551ci
      This is a firmware error code. I've got to step away from this machine for a couple of days. My frustration is getting the best of me and I don't want to make anymore stupid mistakes.
        • 900
        #48
        Re: C2790 - 3551ci
        Reading through your post one thing that sticks out with me is you said you heard a clicking sound . I have had some 3550 with C2730 that when it made a clicking sound it was the transfer release motor on the right door. I know its not the code your getting but its easy enough to try another right door on it .
          • 23009
          #49
          Re: C2790 - 3551ci
          This reminds me of a situation where I was working on a punch unit error on a KM-5052ci:
          As part of my early first attempts, I tried uploading firmware. It went into the IH firmware error 0801, and would not come back to a "Ready" state. The machine always returned to the firmware update screen (with or without the USB stick) ... and if there was a stick with the firmware it always stalled right at the IH firmware EVEN THOUGH THERE WAS NOTHING WRONG WITH THE IH BOARD. It was stuck in some kind of a loop.
          So I removed all the accessories, then reloaded firmware successfully, and it came to "Ready". Then one at a time I re-installed one accessory at a time, with a firmware upload. When I got to the punch, the firmware stalled again at IH firmware.
          I then disconnected the punch, and successfully re-loaded firmware. I later on ended up replacing the punch motor and punch PWB. =^..^=
            • 16416
            #50
            Re: C2790 - 3551ci
            That's exactly what my machine is doing. Exactly. I'm gonna get back on this machine in a couple of days as I feel like I'm going backwards. Thanks for the information, bc.
              • 16416
              #51
              Re: C2790 - 3551ci
              I really don't know where to start on this other than to say this:
              Lets start here: When I replaced the transfer unit connector (bent pin), I had to remove a lot of stuff and one of those things was the fuser drive motor. The motor is hidden behind a bunch of crap and the connector to the fuser drive motor had come partially off at some point during reassembly. So the firmware issue is solved.
              Once the firmware was updated the machine booted up and is running fine now.
              There's too much to go into but lets just say that all of the problems that I experienced were mistakes made by me. But I did learn a whole hell of a lot.
              Thanks to all that helped me.
                • 16416
                #52
                Re: C2790 - 3551ci
                I've been playing around with this Kyocera 3551ci and just out of curiosity. I wanted to see what would happen if I simulated a bad motor (doesn't matter which motor) by unplugging it and then trying to upgrade the firmware as my 1st fix. What happens is the firmware gets stuck in a loop exactly like blackcat describes. This is also what happened to me when I accidentally left the fuser motor unplugged.
                Here's the point I want to make:
                If you suspect that you have a bad motor or that a motor isn't working for ANY reason, I recommend not trying to update the firmware as your first option because it's gonna get stuck in a loop and you will not be able to access the test commands. Instead, I recommend running U030 as a first option and you can check every motor before trying to upgrade the firmware.
                I hope that made some sense.
                PS - I know that's kinda stating the obvious...but just saying.
                • toddanderson
                  • Dec 2005
                  • 236
                  #53
                  Re: C2790 - 3551ci
                  Unplug the hard drive, the firmware is on the hard drive and it will keep retrying firmware.
                  • KYO_OEM
                    • Aug 2011
                    • 721
                    #54
                    Re: C2790 - 3551ci
                    Good idea to unplug the HDD, but from Iris range (TAxx52ci), faulty upgrade would stored on SSD instead of HDD
                    and U030 won`t work anymore if any C-call is in front....
                    Unplug from SSD not possible.....
