M3540idn comfortable max monthly duty cycle?
  • copiertec
    • Jan 2016
    • 2211
    Need to get some opinions on the comfortable max monthly duty cycle on a M3540idn. I have a client that was asking for a tabletop model, they are estimating around 15,000 +/- prints per month. I feel they would be better suited to an A3 model. I feel the max on the A4 models should be 5,000 pages or under.
  • copiertec
    • Jan 2016
    • 2211
    Re: M3540idn comfortable max monthly duty cycle?
    The more I think about it A3 model is the way to go.
      • 16521
      15k seems extremely high for a tabletop model. I'm with you on the A3.
        • 23010
        Here's some food for thought:
        A co-worker of mine went out to PM an ECOSYS M6535cidn, and discovered that it had done the entire PM cycle in three months, without a since service issue, and perfect image quality upon arrival (... as perfect as it gets, i mean to say).
        So maybe some of those pie-in-the-sky, crazy monthly yields may be that high for a reason. Perhaps these tabletop machines don't run for shit at 1000 copies a month, but cruise right a long at 100K per month. =^..^=
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1901
          I think you can get about 30k on the feed tires. You'd be changing them every other month.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
          • patrickjlc
            • Feb 2015
            • 225
            I have a couple of m3540 and 3550idn running on pharmacies with an extra tray unit. They print on average 8k pages from 1 tray and around 2k from the second tray ( they print labels for)
            Only trouble I have encountered is charge rollers don't last very long if customers turn off the heat at night.....
            Heater is a little involved to replace, everything else very easy to get to.
            Sent from my motorola one 5G UW using Tapatalk
            • KYO_OEM
              • Aug 2011
              • 728
