Kyocera FS9530 image distorted
  • buzz
    • Aug 2013
    • 288
    1.5 Mil on this beast
    Recently replaced maintenance kit
    Now images are distorted. Parts of image is squished and expanded. Almost as if the speed of the paper or drum rotation is varying. I seen this on Sharp drums when the core end caps get loose.
    See sample:
    Drum defective perhaps?
    Anyone seen this issue?
  • copier tech
    • 8174
    Re: Kyocera FS9530 image distorted
    See sample:
    [ATTACH=CONFIG]48532[/ATTACH]
    Assuming the fault was not present before you replaced the kit? Fit each old part back one at a time & see which item is defective.
    I would start with the transfer unit.
      • 23009
      Prints or copies or scans? Using the DF? =^..^=
      • buzz
        • Aug 2013
        • 288
        Prints.
        No DF.
        Monochrome printer.
        And I believe it's reports generated from a database program, so no pdfs or jpegs bring printed.
        • Santander
          • May 2009
          • 768
          As Copiertec has suggested, replace the old items back in one at a time. I have not seen this on the FS9530 printer, but have seen it on its copier sister where it was the drum bushing binding up, that would be the first item I would replace.
          • spw
            • Mar 2015
            • 62
            Had one do similar. The metal drum entry guide in the MK was a tad warped. Swapped it and the problem went away. might start there, pretty easy swap.
            • spw
              • Mar 2015
              • 62
              its the part that you have to put the sticker label on
              • buzz
                • Aug 2013
                • 288
                Adobe Scan Mar 16, 2021.pdf
                Latest: Replaced all parts from another new MK. Still same issue.
                • kjg
                  • Mar 2009
                  • 112
                  Did this only happen after the MK was installed? If new MK was put in to correct, go and check the clear guide films that come in the kit. If they are installed too high they will interfere with the nip of the registration roller. Also check for proper registration roller (the gray one in the conveying unit) installation to be sure its not binding any. That sample shows a repeating pattern of error. I hope you find it.
                  • Copier Mechanic
                    • Mar 2023
                    • 89
                    [ATTACH]48618[/ATTACH]
                    [ATTACH=CONFIG]48619[/ATTACH]
                    So what was the problem assuming you got it fixed by now??
                    • GIUBOSS
                      • 1436
                      Have you tried blocking the print or copy before it gets to the fuser
                        • 30303
                        9530 is printer only
                        clean slit glass if that doesn't fix
                        clean mirrors in the laser unit
