Kyocera 6052ci 7620 7611 7614 7613
  • fishleg
    • Mar 2009
    • 426
    Re: Kyocera 6052ci 7620 7611 7614 7613
    Originally posted by KYO_OEM
    We created door switch set by 3D printer
    See enclosed picture for all 4 locations.
    Optical sensor for switch 2 is located on the left side behind the "A1".(It was easier to block "A1" by using the right position)
    [ATTACH=CONFIG]48596[/ATTACH]
    Wow love that you 3d printed parts to fool the machine. Weird it doesn't just let you do it anyway but suppose someone would jam there hand in the fuser to see if its turning..
      • 22973
      Can you get a few close-ups of the interlock devices? I think I could make something up.
      • KYO_OEM
        • Aug 2011
        • 704
        Now i created short explanation....
        You also can use pieces of paper or else and tape for blocking the parts.
        Special keys normally not needed. (but easier...)
        Please share
        • KYO_OEM
          • Aug 2011
          • 704
          #19
          i added additional page with pictures from the keys to the explanation
