Re: KM-3252ci black only banding issue crossfeed
Following up. Finally got the parts and some time to go back.
Secondary transfer roller was clean/uncontaminated. I added a little conductive grease at the contacts: no change.
I started with using conductive grease on the black primary transfer roller front bushing and contact spring. That alone cleared up a lot of the voids (37mm and 45mm), but the 94mm void remained.
I them replaced the HVT and did a color calibration ... and it looks perfect ... at least for now. Time will tell.
Thanks for the help! =^..^=
