CS-3010i intermitent black lines when printng or copying
  • mad
    • Jul 2010
    • 25
    Hi,
    i have this problem with 2- CS-3010i and 1- CS-3510i all installed on different offices/customers
    Problem:
    Intermittent black lines across pages, perpendicular to the page movement. (see the attachments) it can print fine for a few hundred pages or show the problem few times a day.
    already replaced:
    Drum Unit, Developer unit, bias voltage board, reconnected connectors on boards.
    The cs-3510i started showing the problem when it was almost new. i had to replace all 3 machines and now i have them in my warehouse.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1888
    Re: CS-3010i intermitent black lines when printng or copying
    Bulletin I003 might be of interest to you.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
      • 23009
      That looks like a laser failure, to me. =^..^=
      • avio2
        • Jul 2010
        • 150
        same problem whit utax 3060 and utax 2540
        there are false contacts between the connectors main charge, drum dv unit and those in the main body
        • mad
          • Jul 2010
          • 25
          Could you explain the steps to resolve the false contacts?... since the contacts have springs and i already stretched them but the problem persist...
          Thanks in advance!
            Thanks in advance!
            yes you pulled the springs out BUT are they making the proper contact with the units?
            were the drum/dev units you replaced NEW or were they pulls from another machine?
            did you init them in service mode?
            have you cleaned the laser glass? BC mentioned the laser have you tested that?
            • avio2
              • Jul 2010
              • 150
              • mad
                • Jul 2010
                • 25
                Thanks for you reply Phil B
                new developer and drum,
                the laser is clean and working as shows the enlarged image (the text can be seen "behind" the black line (green arrow)
                the lack of a white margin (red arrow) tells me is a problem with the developer bias voltage or maybe a drum ground problem...
                the path of the Developer bias voltage has many "steps" and a 3 or more springs to get to the magnetic roller.
                each one of this "steps" is a possible false contact. and the springs are difficult to handle because their location.
                i was hopping that someone had figured out...
                  • 23009
                  • Gab
                    • Aug 2015
                    • 671
                    Are black lines repeted at same distances. If yes from these distances you can find what cylinder (drum, chatge etc) it causes it (the perimeter is equal to distance).
                      • 23009
                      On Kyoceras, most crossfeed defects are accounted for by primary charge loss or arcing, or loss of drum ground. =^..^=
                      • Samanator
                        • Sep 2017
                        • 579
                        Just gonna throw this out there, maybe it will help.
                        3010i-3510i Repetitive Defects Guage
                        See attached.
