TASKalfa 6052ci
  • EDSNOW
    • 187
    [Misc] TASKalfa 6052ci
    Just curious if anyone has had the issue of seeing the developer and drum units where the grey latch (as I call it) won't stay in place when pushed in.
    Had to replace the black units and noticed the yellow and cyan units were not locked in.
    I have changed components in the past without any problem. I have seen some machines where the customer has tried to remove the units thinking they were
    toner cartridges and released the units and I would reseat and lock in without a problem.
    I did discuss with Kyocera USA support and their database indicated there had been a similar issue(s) and resolved by replacing the drum/developer units as there was nothing
    else related to resolve the problem.
    Appreciate any replies from anyone else who might have had this happen.
    Ed
  • Samanator
    • Sep 2017
    • 579
    Re: TASKalfa 6052ci
    I have experienced the same problem with some of my two series. I was told by Kyocera support to change the offending developer unit and put it in for warranty return. And that's OK if it's still under warranty.
    What I have done to one unit that wasn't under warranty was to stick a bit of paper next to the button so it wouldn't come undone. See the attached pictures.
    That was last week. Haven't heard anything as yet. We shall see.....
    opps. Got the pics out of order when I attached them.
    • EDSNOW
      • 187
      Re: TASKalfa 6052ci
      Greatly appreciated.
      In my case the unit is under warranty but I will give your suggestion a try.
      Regards
      Ed
        • 23010
        Re: TASKalfa 6052ci
        Our techs are driving a small sheet metal screw into the gap between the button and the cover. It holds and is easily removed. It's not a great design.
        • EDSNOW
          • 187
          Re: TASKalfa 6052ci
          Much appreciated Blackcat
          Regards
          Ed
          • Samanator
            • Sep 2017
            • 579
            Re: TASKalfa 6052ci
            I agree with you Blackcat.
            It is not a great design.
            Those engineers must have been watching an old Inspector Clouseau movie where he's talking about the poppout lighter in the car. They must have thought the poppout button on the developer units are a great idea.
              • 906
              Re: TASKalfa 6052ci
              I am just glad the design actually gives us a easy fix to the problem.
              • Ropariva
                • 693
                • avio2
                  • Jul 2010
                  • 150
                  Re: TASKalfa 6052ci
                  I have lengthened the return spring hooked on the bar
