Kyocera CS 3552ci leaving line/smudge on first copy
  • StratManDan
    • Nov 2018
    • 96
    [CQ] Kyocera CS 3552ci leaving line/smudge on first copy
    Hi all,
    I've got a CS3552ci in the field that is laying a black line/smudge on the first print, but none on the following prints, if running multiple copies. I thought this line/smudge may be coming from the transfer belt cleaning brush, or the felt roller, just under the plastic cover, on the transfer belt, that covers it. I can clean this, resolving the issue, but it seems to come back very quickly.
    Most all of the larger machines that use a TR-8550 Transfer Belt seem to have this issue at some point.
    Has anyone seen this issue, and found a remedy for it?
    Thanks!
  • KYO_OEM
    • Aug 2011
    • 725
    Re: Kyocera CS 3552ci leaving line/smudge on first copy
    Today i got phone call from fieldtech regarding maybe similar issue.
    See below explanation from KDC
    After switching from U100 i got positive feedback
    • StratManDan
      • Nov 2018
      • 96
      This is exactly the same issue. Thank you very much for sharing this! Great work!
