TaskAlfa 3551ci - "black toner empty"
    • 30306
    #16
    Re: TaskAlfa 3551ci - "black toner empty"
      • 23009
      #17
      You won't have to repeat that one. When you have to think that hard on a fix, it sticks. =^..^=
      • fishleg
        • Mar 2009
        • 426
        #18
        I just got back from the machine and it wasn't the the side door that was open..it was the small door at the top of the copier that wasn't closed good. I'm talking about the door at the switchback unit for the finisher. Like someone else said, the machine wasn't showing the door was open because it was showing black toner was empty and the machine couldn't clear that toner empty condition because the door was open.
        It really pisses me off at myself for not figuring it out sooner. I'll know better next time.
        Wow thats a good one. You would think the open cover message would be first then toner second??? I think that needs to be fixed in firmware surely.
        Is there anyway to see the open cover message on the screen behind the toner message?
        • tsbservice
          Field tech
          • 8020
          #19
          Not sure but maybe there's another screens of animation showing this.
            • 16416
            #20
            I meant to follow up on this post.
            So, I recreated the toner empty (with door open) scenario here at the office.
            I noticed that at the very bottom of the LCD screen, in very small letters, it says "main unit open".
            I swear that I didn't see it on the customer's machine. But I must admit that it would be easy to miss.
            The important thing here is that no one makes fun of me. This problem already made me feel like an idiot.
            PS - It doesn't make any difference what door is ajar, the screen still says: MAIN UNIT OPEN.
            • tsbservice
              Field tech
              • 8020
              #21
              I have this on Konica C258 like I said but it was second screen showing the door is open. Just did it on Konica C250i in office and it's the same: I pull one of toners and close front door - machine complains about incorrect toner cart setup - I open side door slightly and on main display it immediately show an arrow that there is second animation screen - I press an arrow and machine switch display to animation showing that side door is open. There is no matter which door is open - ADF, machine, Finisher, etc. I think it is NOT FW related at least on Konicas so having and following correct Movie/Animation data is important
                • 16416
                #22
                There is no second screen on the Kyocera. It's no big deal now that I've seen the problem but it was a bitch the first time around.
                • dschultz31
                  • Aug 2018
                  • 33
                  #23
                  Originally posted by darry1322
                  Out of left field here but....I've ran across this a couple of times.
                  If the side transport door was opened while the toner message is displayed and then closed but not quite completely closed, the toner message will not clear after replacing the toner.
                  Customer opens the side door and closes it by pushing it on the front top and rear top is still slightly open. Then changes toner.
                  The machine doesn't show a door open message because the toner message hasn't been cleared and the toner message doesn't clear because the side door is "open".
                  Worth checking.
                  I've had this exact thing happen on a M6530. Change (C) but it wouldn't go away even after replacing it. A two hour drive later and I close the rear door. Toner now excepted.
                  • fishleg
                    • Mar 2009
                    • 426
                    #24
                    I have no idea why but I've been seeing this on the newer ones 5053ci series. What worked for me is I removed all the toners and put them back in and boom message went straight away. It was like one of the colour toners was causing it to not accept the black was very strange. I had to do the magnet thing to open and remove the toners but when I did it worked straight away no problems after. I even took out the black a second time after just to see if the customer would have the problem again later but worked fine after that.
                    • KYO_OEM
                      • Aug 2011
                      • 721
                      #25
                      Have had same on 2 xx52ci.
                      Toner "Y" empty message on the screen.
                      Print in bk works well.
                      Opened toner covers and installed all cartridges again, but still no luck.
                      Taken out event log by U000/ USB/ *.txt file and saw BK cartridge would renewed 600 pages before.
                      Used other bk cartridge,closed toner cover again and "adding toner Y" message comes up, finally system works well again....
                      • peterfinn
                        • Mar 2022
                        • 1
                        #26
                        Worth checking.
                        Thank you,
                        Same issue, different machine (351ci) pointed me in the right direction.
