TaskAlfa 3252ci - Error Developer-Y
  • Ramatzko
    • Jan 2017
    • 5
    [Misc] TaskAlfa 3252ci - Error Developer-Y
    Hello
    I have a strange error on a Kyocera/Copystar 3252ci.
    We already changed the yellow developer 4 times but after about 2500 printings the error occures again.
    We also changed the yellow drum, the high-voltage-board and the EEPROM (got this from Kyocera directly). But it couldn't solve the problem.
  • Samanator
    • Sep 2017
    • 575
    Re: TaskAlfa 3252ci - Error Developer-Y
    Just a first glance at this, but isn't that the same pattern as the spiral foam cleaner on the charger roller? Also, maybe, laser?
    • Ramatzko
      • Jan 2017
      • 5
      The same "spiral cleaner" is build in the developer unit. After changing the DV-Y, error is gone for 2500 prints, then it occures again.
      I think the problem is, the developer-unit runs empty after this 2500 print-pages. But I don`t know why.
        • 16316
        I read where you changed the high voltage board, but did you ever bother to take any voltage readings? I think I'd be checking some voltages and stop replacing the yellow DV unit over and over again.
          • 22999
          Are you getting false "Add Toner" indications? =^..^=
          • tsbservice
            Field tech
            • 7981
            I would check Y drum erase LEDs/lamps. Your yellow developer is finding its way into waste you should find why. Double check machine filters if clogged they also may cause this.
            • 40yearsplus
              • May 2020
              • 113
              See if you have a sensor built into the developer that tells the unit when the toner percentage is right in the developer, it would plug into a small probably 2 prong plug. If one is bad it may not add toner. You can swap sensors with the other color units. You could have any type problem if your toner drive has a problem also. The erase lampe is a possibility, if you can shut it down at the end of a copy cycle before it shuts off if the drum is coated with Yellow toner then they would not be lighting up to clean the drum and use up toner.
              These 2500 copies you state work well could be with the pre mixed toner/dev when you add it depending what black to white ratio you are running.
              Start with seeing if your toner is dropping into the developer, if not swap the sensor, check toner drive for problems. If you can run a toner drive for yellow simulation do thsat.
              Lots to try, going to the service manual page here would be a help. I don't service this particular copier but sure its like others. That sensor is a piezoelectric and activates when toner is needed if this unit uses it. Some newer Xeroxs did I have worked on.
              Let us know how you fix it.
              • Ramatzko
                • Jan 2017
                • 5
                First: Thanks you all for these helpful posts!
                When the error occures, the developer-unit is dead. (I tried them in another machine and it`s not recovering)
                First change: I changed DV because I thought its faulty
                Second change: I changed developer again (Kyocera told me they had some defective developer-units in stock but improved them)
                Third change: I changed the HV-Board and the DV (The voltage-readings from maintenance-mode are normal, compared to another 3252ci )
                Fourth Change: I changed the EEPROM and the DV (as Kyocera told me)
                @blackcat4866 There are no wrong "Add Toner" indications.
                @40yearsplus I also opened the faulty developer-unit. In this unit is no toner-sensor inside (I know the sensor from all the previous machines). The defective developer-unit is nearly empty (a few crumbs developer/toner inside).
                On friday I will take a look at the Hopper-Unit and the Toner -Drive (good idea).
                • 40yearsplus
                  • May 2020
                  • 113
                  So you did put a Brand New Developing unit in the unit not just the developer. There is a name for that problem you have and it is called Barber Poleing, and I have seen a lot of my fellow techs have to replace the whole mechanical developer unit also to cure this, but just making sure thats what you replaced not just the Iron Filings (Developer).
                  Hang in there you will get it.
                  Remember to look for that Manual in the section here or ask for a Service Manual.
                  • KYO_OEM
                    • Aug 2011
                    • 709
                    For better understanding how toner control on Iris series is working look for the attachment.
                    @40yearsplus:
                    Instead of magnetic detection, now we have frequency detection
                    @Ramatzko:
                    In your case, maybe we get problem with the controlling by Feed Image PWB and/ or Engine PWB.
                    DV connected to Drum_DLP_Connect PWB --> Feed Image PWB incoming on YC17/ outgoing by YC28 --> Engine PWB incoming on YC42
                    If we have bad connection, maybe system won`t recognize real value and engine won`t start toner motor for adding toner.
                    Look for U155 at first and check wirings between the pwbs.
                    By the way:
                    Did you unplug the power plug from the wall outlet before exchange from the DV units?
                    Did you run ALL needed adjustments after mounting?
                    Check U157, U158 and U984 for correct values.
                    If counters and/ or SN not real, system can`t calculate need amount of toner in the right way.
                    • fishleg
                      • Mar 2009
                      • 426
                      @40yearsplus:
                      @Ramatzko:
                      By the way:
                      I agree you gotta follow that sheet of paper to the letter.
                      You used new units? Sorry daft I know but these units are once they are in a machine they are done and can't be moved to another machine.
                      I had a similar problem but it happened on two colours on mine cyan and magenta so I did the toner hopper c/m Dev units and never been back.
                      I'm sure one of the modes give you the TCR sensor readings I'd look there and if the sensor is fine it will be a completely different value to the others.
                      • avio2
                        • Jul 2010
                        • 150
                        i think this is the problem?
                        302L794030 PARTS PWB DRUM DLP CONNECT ASSY SP
                        • Luther
                          • May 2006
                          • 682
                          its not adding toner to the developer unit thats why when you install a new unit the code goes away, i would pull the main drive unit and back out all the drums nd dv units, behind the main drive is the toner supply unit, the tube from the toner bottle to the dv unit is clogged, just slide the little door open that mates to the affected dv and vacuum it out, the original dv unit was more then likely frozen and when it tried to add toner to it it clogged the chute, it is a common issue if the dv locks up
                          • Tonerkiller
                            • Oct 2012
                            • 668
                            That pattern means there is not enough toner in the dev unit. Check the dev counter on the maint. list, does the machine know you put in a new dev unit? Were all of the adjustments done?
                            • Hadi
                              • Jan 2019
                              • 15
                              I have exactly the same problem but with the bk dv unit. The machine have 320k pages out. My friend in Kyocera in my Country told me to check the connection between dv unit and another electrical unit (hv unit?) - maybe there is a bad connection and the developer is spilled off. He's told me that is a known problem in that model? Is it? What do You suggest in my situation?
