TA-3551ci - J4401 jam code
    • 16416
    @ arrival, the machine was jamming every time when printing 2-sided. The jam code is J4401. The '01' indicates the paper was fed from tray 1. The "44" indicates that paper is arriving late @ Duplex Sensor 2 (Dus2).
    I attempted to print duplex copies from the other 3 paper sources and get same result.
    Out of the blue it started passing paper when printing 2-sided but it would eventually jam after about 10 pages.
    I searched the forum. Didn't see a definitive answer. I think I'm gonna replace the entire conveying unit to see if that clears the problem.
    Anyone have any feedback on this jam code?
    Thanks.
  • kuby
    • Oct 2007
    • 1409
    Re: TA-3551ci - J4401 jam code
    Make sure all the photo sensors are clean. You would be surprised how a little paper dust will affect these.
    • scottybbb
      • Dec 2010
      • 126
      Replace the duplex clutches.
        • 16416
        Thanks for the advice. I'll check it out.
          • 23009
          Definitely clutches. The rust will be a dead giveaway. =^..^=
            • 16416
            This is the first time I've had the need to disassemble the duplex unit on this model. Duplex Clutch 2 is kind of a bitch to take off, huh?...i took one apart here at the shop.
            I see these are sealed clutches, so no cleaning...they must be replaced?
              • 23009
              Cleaning helps ... but by the time you see the rust they're done for. In an emergency when I only had say 4 of the 6 clutches I really needed, I have disassembled, cleaned all the parts, and cherry-picked the least worn components from the (4) used clutches. It's hardly worth the trouble though. Better just to replace. =^..^=
              • tmaged
                Owner/Service Manager
                • Oct 2008
                • 1888
                This is the same clutch used in multiple locations on these machine. My theory is it has something relevant to the IH section, as the reason it's usually the top one that fails. The bottom one and resist clutch, I believe are the same, and last much longer.
                Hope that helps !
                -Tony
                www.dtios.com
                Become a fan on Facebook
                  • 16416
                  Just to follow up: I went back to the machine this morning and replaced the top clutch and that cleared the problem right up. Thanks to everyone in this thread that helped me out.
                  • fishleg
                    • Mar 2009
                    • 426
                    Might be wrong but I'm sure the bypass clutch is the same so you could steal that if they don't use it.
                      • 23009
                      These same Daiken clutches are used on a wide variety of machines. There are heavier duty versions of this same clutch in the KM-8002i. And almost identical clutches in some Toshibas. Like rollers, I've had success installing what I happen to have on hand. =^..^=
                        • 16416
                        This is the first time I have taken apart the conveying section. There are several (4?) of these clutches in this section. They are all identical. I see no way to take these clutches apart for cleaning.
                        Is this clutch something that I should keep in inventory? I'm gonna guess the answer is yes.
                          • 23009
                          With hemostats squeeze at the area indicated by the arrows. The center tube will slide out. pay attention to the order that the parts go together:
                          I would stock at least (6) clutches. Most Alphards have either (5) or (6) clutches in the feed unit, and if you're tearing it apart, change them all. =^..^=
                            • 16416
                            I just ordered 6 of these clutches. The price was lower than I expected: $18.90 ea.
                            CLUTCH 50 Z35R - 302KV44041, 302KV94520
                            • KYO_OEM
                              • Aug 2011
                              • 721
                              Not only on Venus range you can get problems with clutches.
                              I will share Sirius samples for you.
                              In future, take care about clutches all the time
