TA2553ci Blank line across all colours
  • Elmo
    • Feb 2010
    • 541
    Hi
    i have a TA2553ci putting a fine blank line across all colours
    i have replaced all drums, developers and transfer belt20240516091129049_0001.pdf
    attached page is A3 internal print
    any advise welcome
    I Used To Live To Fix Things Now i Fix Things To Live
  • Larhal
    • 609
    Have you checked if it is a repetitive mark since you said it was a A3 print? Measure the distance between each mark and use the repetitive mark chart in the Service Manual
    Larhal
    If all else fails read the Service Manual!
    If that fails, meet me at the pub and we will discuss it.
    • Elmo
      • Feb 2010
      • 541
      it does repeat on each colour approx. a drum width between lines have worked thru service manual adjustments but still no luck 20240516135945018.pdf 20240516135945018.pdf
      • dalewb74
        • Feb 2018
        • 1167
        cleaned the optics?
        • Larhal
          • 609
          Originally posted by Elmo
          it does repeat on each colour approx. a drum width between lines have worked thru service manual adjustments but still no luck [ATTACH]n1565078[/ATTACH] [ATTACH]n1565078[/ATTACH]
          This May Help:
          Defect.docx
          Larhal
          • Munter
            Member
            • Jul 2011
            • 23
            Those lines are about 94mm apart which on the repeating defect chart is either the drums or pressure roller on a low-end machine. The fact that this is happening on all colours suggests it's not the drum drive as the K and the YMC are on separate drive trains. That leaves the pressure roller. What would be interesting to see would be bands of colour lengthways down the page to see if the line travels through all colours at the same point on the page meaning that it the pressure roller causing the defect. You could temporarily swap the fusing unit between machines.
              • 23010
              I'm leaning towards Munter's explanation. I can't enlarge it enough to see, but I suspect that under high magnification you will see an expansion (light) then compression (dark). I suspect there's a flat spot with the pressure roller or a defect in the fuser drive. A quick fuser swap should help you diagnose it. =^..^=
              • Elmo
                • Feb 2010
                • 541
                Sorry for the delay in reply it turned out to be an issue with the fuser drive
                thanks munter,blackcat
                • Dark Helmet
                  • May 2009
                  • 858
                  The fuser or the actual drive? If the drive, did you notice anything when turning it by hand?
