Kyocera M6235cidn color registration problem
  • martinkrys
    • Feb 2011
    • 29
    Originally posted by KYO_OEM
    You has to ask kyo support for the reset *.capt file.
    My *.capt file does not work on your systems because it`s depended to the first 3 digits from serialnumbers.
    Send status page to your kyo tech und ask for registration reset file.
    I asked, and the answer was "there is no reset file for this type of machine." However, they gave me a solution that works: performing the manual color registration 15 times with extreme values, which is the same solution that blackcat4866 mentioned above.
    • KYO_OEM
      • Aug 2011
      • 719
      i tried to upload my renamed *.capt file, but i don`t know why i am not able to upload *.txt file >19,5 KB for sharing.
      It`s not allowed to upload files >19,5KB....(my file = 49 KB)
      Anyway, i received *.capt encrypted files for all our A4 Mebius systems to run reset by USB.
      I checked kdc data base and found similar requests from KDA in past and kyocera america received reset files for each request.
      You has to ask your kyo tech again, i think.
