Kyocera Taskslfa 5002i (C6770 error)
  • TIADO
    • Mar 2011
    • 7
    I have several Kyocera Taskalfa 5002i photocopiers with a recurring error C6770 which I have now resolved by replacing the entire fuser unit. I wanted to know if anyone has solved it by avoiding the costly replacement of the fuser unit!! Thank you
  • ihatefinishers13
    Senior MFP Technician
    • Feb 2020
    • 695
    Nope. The fusers are junk. Only thing we do is turn on Quiet Mode so they don't run constantly, but then it slows the machine down a tiny bit and takes a little bit longer to first print.
    • Ropariva
      • 674
      • KYO_OEM
        • Aug 2011
        • 714
        take care for this C--6600 (Fixing belt rotation error.pdf
        • ntbann
          • Jan 2012
          • 628
          We go into 346 and turn off fuser mode.
          • TIADO
            • Mar 2011
            • 7
            Thank you !!
            • Scott
              • 196
              What does that do?
              • KYO_OEM
                • Aug 2011
                • 714
                explained in my post #4 by the attachment.
                In case of sleep timer setting >10 minutes the fuser drive will not stop anymore and length from fuser belt will increase.
