TA-406ci Cf27a error
  • copiertec
    • Jan 2016
    • 2211
    Is the Cf27a error code related the the HDD? I looked it up in the service manual in Sec. 7-101, I just want to confirm I am looking at the correct code.
    • 23009
    Re: TA-406ci Cf27a error
    "An error has occurred in the System Management System"
    1) Reformat HDD U024 FULL
    2) Initialize Backup Memory U021
    3) Replace Main PWB
    4) Replace HDD
    5) Retrieve USBLOG and contact SAD
    per Bulletin C031-2LC-0057 Jan 2012
    Do I know what it means? Nope.
    I haven't seen this code before. =^..^=
    • copiertec
      • Jan 2016
      • 2211
      3) Replace Main PWB
      4) Replace HDD
      I read the same thing, Blackcat, and also have never run across this code either. I did run a U021 and will try to run a full format on the hdd to see if it resolves this code or I may even swap out the HDD. This is an off lease machine and I am just prepping it for a sale.
      I have a question... I do not fully understand #5. Do you have any idea what the usblog is?
        • 16416
        Saving the event log to a USB device?
          • 23009
          ... and sending it to somebody at Kyocera. Which somebody? Again I don't know. =^..^=
          • PrintWhisperer
            • Feb 2018
            • 473
            ….. Do you have any idea what the usblog is?
            USBLOG is submitted to KDC for problem analysis via Kyocera support channel(KDA).
            The mode is not listed and the file it creates is protected and cannot be read.
            Whenever a ‘C’ code occurs the MFP doesn’t tell you to turn it off right away, it says ‘Please wait’ and something about gathering data. During that period it is building USBLOG.
            "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
            • copiertec
              • Jan 2016
              • 2211
              Is it something I would submit? I am unsure of how this is done because I have never encountered this before? Could you explain it?
                • 16416
                I'm hoping that KYO_OEM reads this post. He's very good at this kind of problem. Now I'm curious myself.
                • PrintWhisperer
                  • Feb 2018
                  • 473
                  If you have a tech ID contact 1-800-438-6482 (For America’s) and start a case. They can direct you to the USBLOG procedure.
                  I will defer to KYO_OEM as to his level of support.
                  That general class is Print process type error check driver version, try KPDL emulation on the KX driver and update firmware ofc.
                  • copiertec
                    • Jan 2016
                    • 2211
                    Thank you, I did notice the firmware ver. is 5.01, which has been updated to ver 5.03. I am going to format the hdd and update the firmware and see if the Cf27a error codes persist.
                      • 23009
                      its either Stand Alone Device, Small Area Data ...
                      or Sullen Angry Depressed
                      SAD - What does SAD stand for? The Free Dictionary
                      • copiertec
                        • Jan 2016
                        • 2211
                        LOL.. never heard of Seasonal Affective disorder either. (1st one on the list)
                        Sullen Angry Depressed could lead to #2 on the list- Sex, Alcohol, Drugs.
                        • tmaged
                          Owner/Service Manager
                          • Oct 2008
                          • 1888
                          U964 is the code to export the log. You would normally send it to your area service manager from Kyocera, for them to forward to corporate.
                          Also, all of the new machines have U287. You can enable it to automatically try to clear any C or CF codes.
                          Hope that helps !
                          -Tony
                          www.dtios.com
                          Become a fan on Facebook
                          • copiertec
                            • Jan 2016
                            • 2211
                            Thank you, Tony.
                            • sparkycivic
                              • Apr 2017
                              • 348
                              I didn't know about u287 till now!
                              I see that it's ENABLED by default for the CFxxx errors on the new boxes I've got in my showroom. Is that true of the previous models?
                              As far as I can tell, u287 began life on the 308ci lineup, 3011, 2552ci, 4002, M4125, M3655, and M2155cdn/cdw, so it' wouldn't be available in TS406ci...
