TA3551ci / C2840 code
    • 16386
    After searching the forum and consulting the manual, it looks like the most likely culprit is the transfer cleaning motor located near the yellow drum. However, I couldn't find a lot of info when I searched the old threads. Anyone have any advice? As always, thank you.
  • tsbservice
    Field tech
    • 8009
    Re: TA3551ci / C2840 code
    Not for this model exactly but similar I guess:
    Kyocera TA 3550ci error code C2840
    Originally posted by KYO_OEM
    Please check the waste toner motor unit.(Not from Belt, lower left side nearby the yellow drum...)
    Sometimes waste toner stucks inside from this unit.
    See also bulletin 2N4-0038 (F161)
      • 16386
      Thanks. I read that post by KYO-OEM. I called it the transfer cleaning motor, but I was referring to the waste toner motor.
      A little off topic but KYO hasn't been around lately. I miss reading his posts.
      • tsbservice
        Field tech
        • 8009
        Billy it's summer time here in Europe. I guess top techs need more rest. Hopefully he's refreshing for a new challenges.
          • 23007
          CS-3050ci, 3550ci, 4550ci, 5550ci Alphard Venus
          "C1950", "C2840" errors after routine maintenance replacement of the primary transfer belt assembly.
          Transfer belt EEPROM error and transfer cleaning motor errors. 32 pin connector from primary transfer belt unit to body in not completely seated.
          Re-seat 32 pin connector to primary transfer belt assembly. Reset error with U906.
          Years later I followed up another tech that had bent pins in the transfer unit connector. It was a bugger to find. =^..^=
            • 16386
            There was no work done on the machine recently. They placed a service call today and the first thing I tried was U906.
            I accidently bent a pin @ transfer unit connector on a machine that was here at the shop one time and ended up replacing the connector that's mounted in the frame. It was a bitch. I don't think the connector is the problem this time.
            To make matters worse, the copier is in a busy medical office and there's barely any room to work. I'm actually considering bringing the machine back to the shop and giving them a loaner machine as I'm not sure of the fix and the customer is freaking out because this is the only machine in the office and they use it for everything.
              • 16386
              Looking back through my notes when I accidently bent the pin on the transfer belt connector this is what I found:
              Problem: Error Code C2790 after pulling and reinserting primary transfer belt.
              Solution: Found bent pin @ transfer belt connector @ rear frame. Replace connector to correct.
                • 23007
                Looking back through my notes when I accidentally bent the pin on the transfer belt connector this is what I found:
                That's pretty amazing!
                It's kinda handy now, but wait until a few years have passed, and you've got 100K more records just like that. It'll be just like you did that fix just yesterday! Keep up the good work! =^..^=
                  • 16386
                  Gee, I wonder who I learned to keep detailed notes from? Oh, yeah, that would he you.
                    • 16386
                    Welp, I had never pulled the waste toner motor on a 3551ci before. Until now!!
                    It wasn't as bad as I thought it was gonna be but it was a little work.
                    See pic below:
                    • Ropariva
                      • 671
                      See pic below:
                      [ATTACH=CONFIG]49684[/ATTACH]
                      • KYO_OEM
                        • Aug 2011
                        • 712
                        "Well known" problem on older Venus.
                        Sometimes removing from stucked waste was helpfull.
                        Estimated time for me approx 30 minutes.
                        But it would done from me several times.
                        • KYO_OEM
                          • Aug 2011
                          • 712
                          Yes, i am on vacation
                            • 23007
                            See pic below:
                            So this is the cause? Is it just plugged up, or an electrical failure? =^..^=
                              • 16386
                              I decided to bring the machine back to the shop on Monday and when I plugged it up, the code never appeared and hasn't since I brought it here. I'm thinking the ride over here may have jarred the waste toner loose? I don't know???
                              In any event, I'm doing a 600k PM on the machine and I'm gonna replace the waste toner motor and bring it back to them next week.
                              I was actually looking forward to replacing the waste toner motor to see if the code cleared up. I feel cheated out of declaring victory.
                              EDIT: The toner motor in the picture was one that I pulled off a parts machine the other day. I haven't pulled the one from the customer machine yet. I've been busy with other stuff.
